Conservation of linear momentum
The discussion addresses the application of the law of conservation of linear momentum to a body that explodes in air while under the influence of gravitational force. It is clarified that the explosion is considered instantaneous, making the effect of gravity negligible during that brief moment. The change in momentum due to gravity is minimal compared to the initial momentum, allowing for the conservation law to hold as an approximation. Participants emphasize that the impulse from gravity is small enough not to significantly affect momentum during such events. Overall, the conservation of momentum is applicable despite the presence of external forces like gravity during an explosion.
G.Chandra
Why do we apply law of conservation of linear momentum on a body that explodes in air when an external force, gravittional force- mg, is acting on it? The law says that the linear momentum is conserved in absence of the external forces.
hmm that's because the force mg into the time for which the explaosion happens dt=mgdt is aver small qty so
P_{f}-P_{i}=mgdt \approx 0
Welcome to PF!
G.Chandra said:
Why do we apply law of conservation of linear momentum on a body that explodes in air when an external force, gravittional force- mg, is acting on it? The law says that only in absence of external forces the linear momentum remains conserved.
Hi G.Chandra! Welcome to PF! :smile:
Because an explosion, like a collision, is taken to be instantaneous.
So the force from gravity (which takes time!) is zero. :smile:
hmmmm i don't get this explanation of urs?
This means that the law will not be applicable if duration of explosion is longer?
no see it's an approximatiion!
so don't wry about the "law holding" or not
what's assumed is that the momentum change due to gravity is negligible as comapred to the initial momentum
say if teh intial momentum was some 500 untis and the change sone 1 or 2 units then it shud hardly matter u
it's an approximation and works real well
That's the magic of representing extended objects as mass-points. The center of mass will follow the undisturbed trajectory (within reason- a mid-air collision is different than a 'simple explosion'), even though all the little pieces will tumble hither and yon.
A better way to say it might be that the impulse due to gravity,
<br /> F \Delta t = m \ g \ \Delta t<br />
is very small since delta-t is small. Equating impulse with change in momentum, we can also say this does not affect the momentum during a collision or explosion.
yeah perfect that's hwy i had questioned "tiny-tim"!
