Conservation of Momentum and the Spaceman's Return to His Craft
  • Thread starter Thread starter MagikalGiant
The discussion revolves around the conservation of momentum in a scenario where an astronaut throws a spanner to return to his craft. The initial momentum of both the spanner and the astronaut is zero, leading to confusion about how the astronaut can move. Participants clarify that the conservation of momentum applies to the entire system, not individually to the spanner and astronaut. The total momentum after the spanner is thrown must also equal zero, indicating that the astronaut moves in the opposite direction to conserve momentum. The book's solution of 200 seconds for the time taken is questioned, suggesting a need for further analysis of the problem.
MagikalGiant
So I was revising for some tests I've got coming up in July, when I came across this question in the book. It kinda puzzled me, so here I go...
An astronaut of mass 100kg is adrift in space. He is 10m from his spacecraft . To get back he throws a spanner of mass 1.0kg directly away from the craft at speed 5.0ms^-1.
a) Explain why he moves back towards his spacecraft .
b) Calculate how long it will take him to reach the craft.
Now part a) is the easy part, we all know that "momentum before = momentum after" as it's the conservation of momentum law - and so in throwing the spanner, he moves back to his craft (albeit slowly).
My beef is with part b), the time it takes him to do so...
Momentum = Mass x Velocity.
p=mv
Velocity = Displacement / Time
v = s/t
So we have the conservation of momentum, which would be awesome to use right now - but it doesn't work. The total momentum before would be...
Spanner's momentum = mv = 1kg x 0m/s = 0kg/ms
Astronaut's momentum = mv = 100kg x 0m/s = 0kg/ms
So the momentum before is 0ms^-1?
This would make the momentum after = 0, also. So he doesn't get anywhere?
I also tried using v=s/t, as we have s and we need t, but we don't have the v...
The book seems to think it's 200 seconds, but I'm a bit confused as I don't think I have the right information. It's really annoying, though, because I think it might be something simple I'm not thinking about.
Thanks for the help, MagikalGiant.
Welcome to PF!
Hi MagikalGiant! Welcome to PF! :wink:
The total momentum after is 0.
So the astronaut's momentum after is … ? :smile:
conservation of momentum states that the net momentum OF SYSTEM is conserved.
I think you are using it for spanner and astronaut separately.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
