Conservation of Momentum Experiment
The experiment aims to test momentum conservation during an explosion using an air track with two gliders initially attached. After the "explosion," the gliders will move in opposite directions, and photogates will measure their velocities. The main challenge is selecting a method to simulate the explosion, with a spring compression suggested as a viable option. By compressing a spring between the gliders and releasing them simultaneously, they would glide off with equal velocity. Input on this method or alternative suggestions is sought for improving the experiment.
temaire
Design an experiment to determine if momentum is conserved in an explosion interaction using an air track. I need to come up with the procedure for this experiment.
Not applicable.
I have decided to use two gliders that are both initially attached, but glide off in opposite directions after the "explosion". There are two photogates on either side of the explosive, which will measure the time it takes for the gliders to pass through. The problem I'm having is determining what I will use to cause the explosion, making the gliders glide off in opposite directions.
Do you think it would be a good idea if I used a spring to simulate the explosion? Holding the gliders, I could compress a spring between them and then let go of the gliders at the same time. This would make them both glide off in opposite directions with the same velocity.
Does anyone agree or have more suggestions?
