FZX Student
- 6
- 0
Does a ball falling to Earth violate conservation of momentum?
If you take the ball as your system, then gravity is an external force (as arildno stated) and the ball's momentum is not conserved. This is clearly true, as you know the speed of the ball increases.FZX Student said:Consider the ball is in mid-fall, it hasn't hit the ground yet and has not just been released. There are no external forces because gravity is providing the impulse. Is momentum conservered in this case or not?
Its the total momentum of a closed system that is conserved. Not the momentum of a particle. In your case the particle has a force acting on it and as such the momentum changes. There is no law of physics which states that the momentum of a particle is conserved. The gravitational force changs the momentum of a ball in free-fall. However, as someone explained above, the total momentum of the earth/ball system is conserved. The momentum is thereforeFZX Student said:I'm not quite sure I understand. If momentum of a system is to be conserved then pfinal = pinitial. Meaning m1v1=m2v2. The masses will cancel meaning the velocities have to equal. But they don't. If the ball doesn't hit the ground and is just falling, where is the momentum supposed to be conserved?
cparsons10 said:What about when a ball rolls down a ramp. Is conservation of momentum violated?
