Conservation of Momentum Problem?
A cat on a skateboard moving at 2.00 m/s throws a 1.20 kg book at 15.0 m/s to stop, leading to a calculated total mass of 7.8 kg for the cat, skateboard, and remaining books. In part B, the user attempts to find the mass of a book needed to achieve a velocity of -2.00 m/s after stopping, resulting in a calculated mass of 2.11 kg, which rounds to 2.12 kg. However, there is uncertainty about whether the mass refers to a book thrown after stopping or during motion. The discussion highlights potential misunderstandings in the problem's wording and the possibility of an error in the official solution. Clarification on the problem's requirements is necessary for accurate resolution.
r_swayze
A cat stands on a skateboard that moves without friction along a level road at a constant velocity of 2.00 m/s. She is carrying a number of books. She wishes to stop, and does so by hurling a 1.20 kg book horizontally forward at a speed of 15.0 m/s with respect to the ground. (a) What is the total mass of the cat, the skateboard, and any remaining books? (b) What mass book must she now throw at 15.0 m/s with respect to the ground to move at −2.00 m/s?
I got the answer to part A, here is my work for part A:
m1vi1 + m2vi2 = m1vf1 + m2vf2
m1 = total mass of the cat, the skateboard, and any remaining books
vi1 = 2.0 m/s
vf1 = 0 m/s
m2 = 1.2 kg book
vi2 = 2.0 m/s
vf2 = 15.0 m/s
m1vi1 = -m2vi2 + m1vf1 + m2vf2
m1 = (-m2vi2 + m1vf1 + m2vf2) / vi1
m1 = (-1.2*2.0 + m1*0 + 1.2*15.0) / 2.0
m1 = 7.8 kg
Now for part B, I thought I had the correct answer but apparently it is wrong. Here is my work:
From part a
m1 + m2 = total mass of of the cat, the skateboard, and any remaining books
m1 + m2 = 7.8 kg + 1.2 kg
m1 + m2 = 9 kg = mt
mtvi = m1vf1 + m2vf2
9*2 = m1*-2.0 + m2*15.0
18 = -2m1 + 15m2
So m1 + m2 should equal to total mass = 9 kg
m1 + m2 = 9
m1 = 9 - m2
Plug into equation
18 = -2(9 - m2) + 15m2
18 = -18 + 2m2 + 15m2
36 = 17m2
m2 = 2.11 kg
Have I erred somewhere? If you plug in 2.11 kg and 6.88 kg, it comes out roughly correct. Should I be using 9 kg in part B?
Any help is much appreciated
Your solution must be correct but a rounding error. m2=2.1176 kg, should be rounded to 2.12 kg.
ehild
ehild
I tried 2.12 as well, it was still incorrect. Is my method correct?
I think, your solution is correct, but we may misunderstand the text. Maybe it asks the mass of book that the cat has to throw after it has stopped, to gain -2 m/s velocity. Try it...
But also the official solution can be wrong.
ehild
18K
