Conservation of momentum theoretical question
In this discussion, a theoretical problem involves a tennis ball and a basketball dropped from the same height, where the basketball rebounds elastically after hitting the ground and collides with the tennis ball. The key focus is on the conservation of momentum and energy during the elastic collision. The initial assumption is that the tennis ball will return to its original height, but further analysis is needed to determine the actual height it reaches after the collision. The conversation emphasizes calculating the velocities of both balls at various points and understanding the forces acting on the tennis ball during the collision. Ultimately, the discussion aims to clarify the dynamics of the collision and the resulting height of the tennis ball.
i_heart_you
A tennis ball of mass m is held just above a basketball of mass M. Their
centers are vertically aligned. Both are released at the same moment, and
fall a distance of h until the basketball hits the ground, which it rebounds
from elastically, and then undergoes an elastic collision with the tennis
ball. How high up does the tennis ball go?
P = mv
E=1/2mv^2 + mgh
i figured that since all the collisions in this problem are elastic all the energy is conserved so the tennis ball should technically return to the height that its droped from but I don't think that's the right answer. Please any help would be appreciated!
What about momentum? Both balls will have the same velocity before the basketball hits the ground. It will recoil -with what velocity? and collide with the tennis ball, with opposite velocity. Both the momentum and the energy are conserved in this collision. Calculate the velocity of the tennis ball just after collision.
ehild
At the instant of collision, the basketball with tennis ball rebounds with the initial velocity. The reaction experienced by them is (M + m)*g. But the net reaction force experienced by tennis ball is (M + m )*g - mg = ma.
Find a and then h..
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
