Consistent 2-ohm offset in battery internal resistance measurements
105 replies · 19K views · last reply
neilparker62 said:
My thinking is that two batteries in parallel have an equivalent circuit (assuming the simple resistive cell model) of a single emf and half the resistance - also assuming both have the same internal resistance.
So how much do the values differ for ##r##? I ask, because I didn't just make it up. That is a standard method to analyze multi source circuits. I obtained it from my textbook. There must be a reason for the theory, and I wonder if it will show up experimentally?
Using:
$$ V_t = \mathcal{E} - \frac{1}{2}Ir$$
I get: $$ r = 2 \left( \frac{\mathcal{E}}{I} - R \right) = 2 \left( \frac{V_t + \frac{1}{2}Ir }{I} - R \right) \implies R = \frac{V_t}{I} $$
Which makes perfect sense?
EDIT:
Yeah, they are one and the same, I didn't catch that. If you rearrange ## r = 2 \left( \frac{\mathcal{E}}{I} - R \right) ## with the substitution that ##V_t = I R## you get right back to the first equation...:rolleyes:
Sorry for the detour.
DaveE said:
The pro way to do this in a complete EE lab is to do an AC ohm measurement. You can buy instruments designed for this, but you can also set up your own.
Or use a pulse test
Graph titled Total Effective Resistance, Dual Pulse Method (5mA/505mA), plotting voltage (155 to 135) against time in milliseconds (0 to 140); voltage drops from about 148 to about 138 under a heavy drain after the 5 mA stabilizing drain, then recovers.
neilparker62 said:
Still trying to figure out why but if there's a capacitor involved in a better circuit model, perhaps we're dealing with a long RC time constant ?
At the start of a high current test, you are dealing with the immediate availability of ions at and between the electrode surfaces.
Later in the test, you are dealing with the ion diffusion rate that is needed to keep the test current flowing. That will be temperature dependent.
https://en.wikipedia.org/wiki/Arrhenius_equation
After the test, you are dealing with the time needed for the recovery of chemical equilibrium. That is dependent on the temperature and the amount of charge drawn in earlier tests.
neilparker62 said:
Or use a pulse test
Yes this is also better than a DC measurement. But there is the complexity of either making a really square pulse or dividing two time domain waveforms. Narrow band voltmeters (like in a frequency response analyzer) are easier to get good data out of. Even if your modulation is a bit wonky (harmonics, etc.) the filters will only measure the fundamental. While the impedance at, let's say, 100Hz may not be exactly the whole story (see @Baluncore, above), it is well defined and relatively easy to measure accurately. In addition you can add in the modulation without perturbing the circuit parameters (bias points, etc.). So with an FRA you could characterize impedance vs. load current, or vs. frequency, for example.
Your graph suggests you are getting errors less than 1%, which is better than any electronic meter I've used. So are you confident that the errors are not in the meter?
The "LOAD VOLTS" graph in post #14 shows an error 0.07%! You can get that much variation just by wiggling an alligator clip on a contact, and I doubt your meter is that accurate. If the meter has 4-digit readout that is the ±1 digit uncertainty inherent in all digital measurements.
For the graph in post #1 RCALC vs RMEAS, two possibilities come to mind:
  • the meter (or its leads) need calibration and/or repair
  • the battery holder is defective
Try the experiment with one battery (cell), making contact directly to the battery without the battery holder.
You mentioned that you used the same meter to measure the current. The Current range of a digital ammeter has some low, non-zero, internal resistance, which would add to your effective load resistance. Has this been taken into account?
Beg, borrow, or steal a second meter to measure the current at the same time as the voltage measurement.
Please let us know what you find.
Cheers,
Tom
If you are actually doing the experiment yourself, in advance of the class, (you should) then I would recommend doing away with crocodile clips and probes. Replace them with screw terminals ('chocolate block' type connectors) and a proper switch to the battery (in a proper holder). If you compare that with the results of your croc clips and probes you may find sufficient difference to justify giving the class proper connectors.
There are several comments higher up about the time factor of an AA cell under high current. You need to find a 'sweet spot' for a current that's low enough to protect the cell but high enough to give a measurable Vri drop. Such an apparently simple class practical needs to be designed better than one might think and preparation is essential. I have seen (and suffered from) the results of winging it when the equipment / setup is just not adequate for the exercise. ("These experiments never work Sir") It goes with the territory.
Yes, this. Plus you should review "kelvin contacts" or "4-wire sensing" measurements. You don't want the load current flowing through any contacts that would create an extra voltage drop for your meter to measure. The data you are collecting is what your meter sees (i.e. inside the meter). This is critical for sensitive measurements.
Thankyou - exactly my experience trying to do the prac myself ! You'd think it would be a relatively straight forward exercise but the numerous sources of error (due to poor contacts as well as the actual chemistry of the battery) make it quite a challenge to find the 'sweet spot' you mention.
Following is my latest attempt. I am using 2 AA cells in parallel and that is stabilising the readings somewhat at the expense of a more limited range of readings. Some will no doubt quibble that 3 of the 5 readings are 1501, 1503 and 1505 millivolts so right at the edge of the meter's resolution. I take Tom G's point about the battery holder but it's new, the springs are strong and overall it enables more solid connections than probes direct onto battery terminals.
As part of the brief is using a "home-made" resistor one pencil lead supplies 8.8 ohms while the other is used as a variable resistor (depending on where you attach the crocodile clip) enabling the 4 other readings.
Table of five measurements with columns Resistance (ohms), Current (mA), Open cct volts (mV) and Load Volts (mV): 8.8/138.4/1521/1486; 18.6/73.8/1523/1501; 23.9/58.6/1521/1505; 13.6/97.6/1522/1495; 21.7/63.8/1521/1503.
Why are you using two batteries in parallel when the goal seems to be finding the internal resistance of one battery?
To try and stabilise the load voltage readings. I am working on the assumption that if the batteries are identical I will end up with 1/2 the value of r (internal) for a single battery.
I
Yes - I'm aware the range of load voltages is very small - only about 25 millivolts in the last graph I posted.
I think the systematic error in resistance is indeed mainly due to ammeter resistance - many thanks for pointing that out. Will use the regression obtained offset value (y-intercept) to correct the measured resistance value.
Basically, any method is better than the crude method that the OP is suggesting. For a start, if you want to measure internal battery resistance than it is far better to use a low grade, cheap battery that actually has a poor internal resistance. A PP3 (9V) battery will give a voltage drop with lower, more sensible current values - matching the test to the available equipment.
This is one way to start getting some decent results. Basically, this sort of measurement should involve the DMM working over a range that uses all of its sig digits. If you work on the principle of a Bridge circuit, your DMM can be measuring the difference between a reference AA cell that's unloaded and which will keep its volts for days on end. You connect your DMM ( at maximum or appropriate sensitivity range) between the + terminals of the Test and Reference cells and see how that difference varies as you alter the current through the test cell. All that's necessary is to have the negative terminals of the two cells well connected.
Of course, if its necessary to be using a single meter for current and volts measurements then so be it and there's no way of being sure that the currents through the test cell is the same with and without the meter. But schools and colleges usually have more than just one instrument to use.
Digital meters are very handy but they actually tend to play hell with people's understanding of the circuits they are using. We just tick off the item on the syllabus and move on etc. etc.
erobz said:
EDIT:
No worries - we are all learning!
OK, it's really the parallel combination of the source resistances. Which, as you say, is 1/2 for 2 identical batteries.
But, the cell voltage should be stable. Any instability is most likely a problem with your test fixture. Fix that first, adding a second cell probably isn't addressing the root cause and might show up as variation in your impedance data. In a good test setup, I don't see how two cells is more stable than one.
It's more stable because the current draw relative to the charge capacity (amp hours) of the pair of batteries is 1/2 as much. Ideally open circuit voltage does not change or only changes (decreases) very gradually. But if you are drawing a relatively large current "gradual" becomes tangibly "rapid". Try experimenting with a 4 ohm resistor and an AA cell and you'll see that.
We face a classic measurement conundrum. You want to drop more volts across the internal resistance so you increase the current. But in increasing the current, you lose stability of open circuit voltage. That's why an earlier post mentioned trying to find the 'sweet spot' where you are dropping reasonably measurable millivolts across the internal resistance but not affecting the open cct voltage too much.
I tried using a reference voltage and I can't say it made much difference. We're trying to measure millivolt changes and are up against the resolution limits of the meter. Whether I measure one voltage as 1500 millivolts and the other as 1490 or 0 and -10 makes no odds. It is what it is. Also if the instability I have mentioned is at the millivolt level, having extra digits (even if the meter was capable of it) would not make any difference.
Once again I'm going to recommend trying out the measurement and seeing what happens. I can post a video here if you like - my poor student was doing his best with a 10 ohm resistor and the load volts was drifting around all over the place. And I have every sympathy because I had exactly the same problem. Current readings also drifted but less drastically.
You hit the nail on the head with your observation in an earlier post that the trick is to find the "sweet spot" in terms of load resistance and hence current draw.
I'll try to improve on the connections as per your suggestions above.
Oh, I see. That kind of stability!
But with two you are measuring half as much resistance, so to get the same voltage drop you'll need twice the load, right? Then the two batteries should discharge as fast as a single one. Or, if you prefer, each battery only sees half the load current.
anorlunda said:
Then you want to avoid significant discharge of the battery or temperature change. One way to do that is to keep elapsed time of the experiment short. Can you turn it on and do all the measurements in a few seconds?
I've tried to do this by setting up such that the load only connects at the same time as the multimeter probes are put on the battery terminals. Then the idea is it's a touch/release measurement.
An idea that's occurred to me (which is probably way 'overkill' admittedly) is to program a raspberry pi to operate a relay or transistor switch which switches in the load. Then use an analogue input pin to measure the voltage immediately and switch off again. I guess this would be a crude 'pulse test'.
There is a well known saying that the speed of a convoy is the speed of the slowest ship. There is a direct analogue of this, concerning experimental errors.
The parameters you seem to have chosen do not help with errors. Taking twice the current through two cells seems completely pointless.
In the dim and distant nineteen sixties, I did the internal resistance experiment and it was fine. We used old fashioned Zinc Carbon cells and analogue lab volt and amp meters. Also we used a nice hefty Rheostat with good contacts. I don't have my old exercise book available but I remember drawing a graph, getting a straight (enough) line which yielded a 'good' answer; much the same as the rest of the class. The suggestions in my post higher up should give you a good chance of very believable and consistent results. Stick to tried and tested methods and leave the Raspberry Pi until you want to want to data-log the whole thing (and to give the students something more to manage not to understand).
Yup - nothing much has changed it seems (other than the meters!). I would say they used a very flat battery if emf was 1.415 volts and internal resistance > 2 ohms though!
I can imagine all the contributors to this thread running through their memories of this sort of experiment, looking for a credibility gap to explain where the problem is coming from. Basic EE is often outside the comfort zone of teachers (and most normal human beings, aamof).
I can't help feeling that the likely value of r for an AA cell will be around 1Ohm. So the voltage drop should be about 1mv per mA. If the current load is between 0 and 100mA (very representative for an AA cell) then the PD would drop by up to 100mV. That's an ideal set of values for 'school' level equipment. Even the tackiest DMM should be able to measure that with four digits. 0.1V in 1.5V shouldn't be using the least sig digit so what is happening with the DMM?
There's something going on that's messing up the experiment, I'm sure.
The use of two cells just has to be a red herring. I can't remember ever using two cells (and the video doesn't either). Are the cells identical and in states of equal discharge? Chuck one away - or, as I suggested higher up, use one cell loaded and one unloaded and compare the PDs between them to give a voltage measurement of between Zero and 100mV. That's going to give really sharp resolution of V - much better than you actually need.
I think this prac needs a lot more careful investigation. For example in the video , they found an emf of 1.415 volts. I wouldn't mind betting that if you actually measured the cell emf it would be much closer to 1.5 volts. I have a whole lot of used Duracell AA batteries here and they still measure well over 1.5 volts.
Then they tried using a button battery (with not very good connections!) and guess what - the voltage readings fluctuated like crazy. Good winging it to say that it would be a good exercise for students to have to think about "how they would cope with the fluctuation."
My data in posts #39 and #40 gave a regression determined emf of 1518 mV whereas measured was 1521 mV or so. But right 'ball park' anyway. The regression determined internal resistance was 0.23(4) ohms so for a single cell about 0.47 ohms. I think 0.5 ohms is about the right 'ball park' number for typical internal resistance of an AA battery. Probably lower for "high drain" more expensive AA cells.
If I were to do (as indeed I attempted) the same experiment with just one AA cell, I would expand the range of measured load voltage values from 20mV to about 40mV. But then measurement becomes difficult because the load volts are changing continuously. That's why I tried using 2 AA cells in parallel. As I explained in a previous post , that stabilised the load voltage readings at the expense of a narrower range of values.
Other data and measurements I have taken suggest that unfortunately internal resistance of two cells in parallel is not 1/2 that of one cell. You can't win it seems!
How about:
1) use one cell
2) connect the meter to cell
3) document the reading
4) connect the load
5) after a timed 5 (or 10) seconds, read the meter and document it
If connecting two in parallel made a difference to the 'stability' of the volts then something is wrong with either the batteries (not identical) or the holder (dodgy contact). What technical reason could affect the stability if the setup was OK? If the cells in parallel don't show half the value of r then they cannot be matched; you need to investigate that and clear the problem before moving on.
Connecting the two - terminals together and then putting the meter across the two + terminals should show near zero V. Does it vary over time?
I have been experimenting on various Duracell Plus AA batteries. In light of the following information from that particular cell's datasheet, I rather wonder if I'm not trying to measure something that doesn't exist or is too small to be measurable ??
The relevant datasheet can be found here and it states 65 milli ohms "impedance" at 1 kHz. ie 0.065 ohms!
DC resistance varies with DOD (depth of discharge) as per graph below but seemingly does not exceed 0.15 ohms.
It definitely does exist.
That depends on your test setup. It is measurable if you try hard enough and spend enough time and money on good instruments and test fixtures.
On one level it does not exist. The model of a battery as a perfect voltage source in series with an immutable resister certainly does not exist in real life.
But as an hueristic and at least semiquantitative tool it is obviously useful, particularly if you don't suck on the battery too hard. Consider it the Thevenin equivalent of a horrible bunch of temperature-dependent and memory-laden wetware.
For precision measure the optimal is nearly always some form null measure using a bridge. I am unaware but surely there is a standard "four wire" technique to do this measurement at the zero current level. Shall we invent one?
