Imolopa
- 20
Im trying to understand what would be the correct approach for calculating the constant pressure specific heat for an ideal gas undergoing a process where the temperature is changing.
The reason I am asking is because the equation used to calculate Cp0 is dependent on the temperature. So when you want to calculate the work or/and heat exchange for a process where the temperature is changing over time, would you still use this equation and in that case what temperatures would you input? Maybe sum up the start temperature with the end temperature and divide the result by 2? That last method doesn't seem like it would be a very accurate way of doing it, therefore I believe there must some other way that is commonly used?
Cp0 = C0 + C1θ + C2θ2 + C3θ3
where θ = T /1000 and Ci = constants (gas dependent) found in tables[/B]
