- 810
fluidistic said:Yeah I must find the rotation matrix and apply it to diagonalize rho.
I've just found the matrix ##\hat n \cdot \vec S##. It's worth ##\frac{\hbar}{2} \begin{bmatrix} \cos \theta && \sin (\theta) e^{- i \phi} \\ \sin (\theta )e^{i \phi} && - \cos \theta \end{bmatrix}## where I've used the spherical coordinates, theta is the zenith angle and phi is the azimuth one.
I just looked at this matrix again, and I'm sorry but you made a really confusing use of the angle θ here. The θ here is not the same as the θ you had in your previous equation for the rotation matrix ##U##. The θ in ##U=\cos(\theta/2)\hat{I}+\sin(\theta/2)\hat{n}\cdot \vec{S}## is the rotation around the unit normal vector. The θ you have in this matrix is the polar angle of the unit normal itself.
A rotation in 3-space requires 3 angles, not 2! I got confused on this point for a minute.
So once you can relate ##\alpha,\beta## which has 3 independent components, since they are 2 complex numbers with 1 constraint, with ##\theta,\phi,\eta##, where ##\eta## will replace one of the ##\theta##'s that you used, you will have the final answer.
Whew! That was confusing!
