Constructing the electromagnetic tensor from a four-potential
The discussion revolves around the construction of the electromagnetic tensor from a four-potential, focusing on the calculations involved and the potential discrepancies arising from different coordinate systems. Participants explore the theoretical aspects of electromagnetic theory, particularly in the context of general relativity and coordinate transformations.
  • One participant describes their process of constructing the electromagnetic tensor from a four-potential, detailing their metric and calculations.
  • Concerns are raised about the appearance of metric functions in the contravariant electromagnetic tensor, leading to questions about the correctness of the calculations.
  • Another participant suggests checking the order of matrix multiplication when raising and lowering indices, as well as verifying the inverse metric tensor and change of coordinates matrices.
  • A participant mentions the necessity of using covariant derivatives for calculating the curl, prompting a response that clarifies that in a freely falling frame, the standard form of the curl can be used without covariant derivatives.
  • There is a discussion about the need to convert results between coordinate and orthonormal bases, emphasizing the importance of proper scaling with respect to the metric.
  • References to literature are provided for further reading on the topic, including suggestions for specific sections in well-known texts on general relativity.
  • A participant expresses confusion over obtaining zeroes when applying the curl expression involving the Levi-Civita tensor, questioning the correctness of their approach.
Participants do not reach a consensus on the best approach to take when calculating the curl or the electromagnetic tensor, indicating that multiple competing views remain regarding the use of covariant derivatives and the handling of coordinate transformations.
Participants highlight potential limitations in their calculations, such as assumptions about the coordinate systems used and the need for careful handling of indices and transformations. There is also uncertainty regarding the application of the Levi-Civita tensor in the context of the curl calculation.
coleman123
*Edit: I noticed I may have posted this question on the wrong forum... if this is the case, could you please move it for me instead of deleting? thanks! :)
Hello, I am having problems on building my electromagnetic tensor from a four-potential. I suspect my calculations are not right. Here are the steps:
My metric is (coordinates are t,r,z,ø):
[itex]\left(<br /> \begin{array}{cccc}<br /> e^{2 \psi (r,z)} & 0 & 0 & 0 \\<br /> 0 & -e^{2 \gamma (r,z)-2 \psi (r,z)} & 0 & 0 \\<br /> 0 & 0 & -e^{2 \gamma (r,z)-2 \psi (r,z)} & 0 \\<br /> 0 & 0 & 0 & -e^{-2 \psi (r,z)} r^2 \\<br /> \end{array}<br /> \right)[/itex]
Then I have a magnetic vector potential in spherical coordinates (the coordinates are r,θ,ø):
[itex]\left\{0,0,\frac{4 \pi M \sin (\theta )}{3 r^2}\right\}[/itex]
I convert it to cylindrical coordinates r,z,ø:
[itex]\left\{0,0,\frac{4 \pi M r}{3 \left(r^2+z^2\right)^{3/2}}\right\}[/itex]
I build my contravariant four-potential (the electric potential is zero):
[itex]\left\{0,0,0,\frac{4 \pi M r}{3 \left(r^2+z^2\right)^{3/2}}\right\}[/itex]
I will use this formula to calculate the covariant electromagnetic tensor components:
(1)
So I need the covariant four-potential, which I obtain by multiplying the contravariant four-potential by the covariant metric tensor, and performing a summation I get:
[itex]\left\{0,0,0,-\frac{4 \pi M r^3 e^{-2 \psi }}{3 \left(r^2+z^2\right)^{3/2}}\right\}[/itex]
Using (1) I calculate the covariant electromagnetic tensor, and then, raising indexes, the contravariant one is:
[itex]\left(<br /> \begin{array}{cccc}<br /> 0 & 0 & 0 & 0 \\<br /> 0 & 0 & 0 & \frac{4 e^{2 \psi (r,z)-2 \gamma (r,z)} M \pi \left(2 r \left(r^2+z^2\right) \psi ^{(1,0)}(r,z)-3 z^2\right)}{3 \left(r^2+z^2\right)^{5/2}} \\<br /> 0 & 0 & 0 & \frac{4 e^{2 \psi (r,z)-2 \gamma (r,z)} M \pi r \left(3 z+2 \left(r^2+z^2\right) \psi ^{(0,1)}(r,z)\right)}{3 \left(r^2+z^2\right)^{5/2}} \\<br /> 0 & -\frac{4 e^{2 \psi (r,z)-2 \gamma (r,z)} M \pi \left(2 r \left(r^2+z^2\right) \psi ^{(1,0)}(r,z)-3 z^2\right)}{3 \left(r^2+z^2\right)^{5/2}} & -\frac{4 e^{2 \psi (r,z)-2 \gamma (r,z)} M \pi r \left(3 z+2 \left(r^2+z^2\right) \psi ^{(0,1)}(r,z)\right)}{3 \left(r^2+z^2\right)^{5/2}} & 0 \\<br /> \end{array}<br /> \right)[/itex]
The notation above, next to my metric functions [itex]\psi[/itex] and [itex]\gamma[/itex], indicate derivatives:
(1,0) is a derivative in r
(0,1) is a derivative in z
I was not expecting my metric functions [itex]\psi[/itex] and [itex]\gamma[/itex] to appear on my contravariant electrogmagnetic tensor. I would like a help if I did all the steps right.
If I just take the curl of the magnetic vector potential to find the magnetic field, and plug in the expected components on the electromagnetic tensor, I get a different result, and was expecting the same... that is what bothers me. I'll show this now.
Calculating the magnetic field from the magnetic vector potential in cylindrical coordinates results in:
[itex]\left\{\frac{4 \pi M r z}{\left(r^2+z^2\right)^{5/2}},-\frac{4 \pi M \left(r^2-2 z^2\right)}{3 \left(r^2+z^2\right)^{5/2}},0\right\}[/itex]
I can then plug the Br and Bz components directly in the electromagnetic field tensor which is defined as (my c equals 1, and instead of x,y,z I have r,z,ø):
So when calculating the electromagnetic tensor this other way, I obtain a different result, without my metric functions [itex]\psi[/itex] and [itex]\gamma[/itex].
What is happening? Thanks in advance for any clarifications on this issue..
It's pretty hard to figure out exactly what's happening because the calculations are long and tedious. Even the results are long and tedious. I have a few suggestions on where one might start looking.
1) Check if when you raise an lower indices, that you get the matrix multiplication order correct, unless of course, you do everything manually by making the summations.
For example:
$$F^{\mu\nu}=g^{\mu\rho}g^{\nu\tau}F_{\rho\tau}$$
In matrix multiplication this would be ##g^{-1}Fg^{-1}## and not for example ##g^{-1}g^{-1}F##.
2) Make sure your inverse metric tensor matrix is correct.
3) Make sure your change of coordinates matrices are correct.
4) As above, make sure your change of coordinates matrix multiplication is correct.
5) Make sure you are taking the curl in cylindrical coordinates, with the correct coefficients in front of the derivative operators.
These are some common mistakes. Have you tried checking these?
Hello, thanks for the help. I did everything in Mathematica, so I think the results are ok, unless I messed up with the indexes.
I heard that I must take the Curl using covariant derivatives... is this correct?
coleman123 said:
I heard that that I must take the Curl using covariant derivatives... is this correct?
No you don't need to use covariant derivatives. In a freely falling frame the curl just takes on the usual form from vector calculus and electrodynamics. In an arbitrary coordinate system the curl of a vector field ##\xi^{\alpha}## is given by the quantity ##\omega^{\alpha} = \epsilon^{\alpha\beta\gamma\delta}\xi_{\beta}\nabla_{\gamma}\xi_{\delta} = \epsilon^{\alpha\beta\gamma \delta}\xi_{\beta}\partial_{\gamma}\xi_{\delta}## so you can use ##\nabla_{\mu}## or ##\partial_{\mu}## (this is assuming a torsion-free connection as is usual in GR). Here ##\epsilon^{\alpha\beta\gamma\delta}## is the 4-dimensional Levi-Civita tensor density (not symbol!). In an arbitrary Lorentz frame this same equation for the curl holds but since we are now working in an orthonormal basis, ##\epsilon^{\hat{\alpha}\hat{\beta}\hat{\gamma}\hat{\delta}}## is just the Levi-Civita symbol.
Alright, since the equation (1) is the Curl, I must do it in cylindrical coordinates. That is where I am making the mistake... If I follow (1) the way it is, it gives the Curl in Cartesian coordinates.
That paper calculates things in an orthonormal basis. Your original calculation involves a coordinate basis. You have to convert your results from one to the other depending on which you wish to work with. In your case this just involves a simple rescaling of the coordinate basis by appropriate factors of the metric in your original coordinates since the coordinate basis is mutually orthogonal. See my comment in post #4 about ##\epsilon^{\alpha\beta\gamma\delta}## as a tensor density vs. a symbol in the expression for the curl.
Do you have a book or site reference on that WannabeNewton? Thanks for the help.
See Appendix J of Carroll "Space-time and Geometry", Appendix B of Wald "General Relativity", and especially most importantly section 8.4 of MTW.
I tried to apply:
But got zeroes... are you sure it is the correct expression? Maybe was my Levi-Civita tensor.
  • · Replies 26 ·
  • · Replies 38 ·
  • · Replies 25 ·
