Construction of a model of a hydraulic damper
21 replies · 6K views
magicfrog
TL;DR
Study of a hydraulic brake based on the flow of hydraulic oil through an adjustable orifice. The aim is to develop a computational model that closely matches the simulation results.
Hi everyone, I’ve tried searching the forum for similar topics but I don’t think I’ve found anything relevant to my specific situation. That’s why I’m here to start this new thread.
I am currently studying a hydraulic brake. The spring-operated system is capable of varying its speed (e.g. linear motion) by opening and closing an orifice, which alters the flow rate of the hydraulic fluid. This is a classic choking valve problem.
Using SolidWorks software and with access to the Motion module, I can simulate this mechanism by applying linear or rotational damping, specifying a value and a law (linear, quadratic, cubic).
What I would like to do is relate this hydraulic damper – caused by oil flowing through an orifice – to a coefficient that can be used in the equations, and find an equivalence with the values I can simulate using the software. I wonder: are there any examples where a damping coefficient can be derived from the analysis of a choked valve problem? Are there any theories and practical examples that have been tested?
The idea is to build a model that can determine a motion damping coefficient based on changes in the airflow passing through the orifice.
I hope I have explained my question clearly enough; if not, please accept my apologies, and thank you to anyone who can help.
Damping is often approximated using an ideal dashpot. Is that what you are searching for: an approximate equation for the dashpot coefficient as a function of the damping fluid and hydraulic damper design? Are you considering doing experiments to measure the damping coefficient in independent tests?
Yes, I would like to develop a mathematical model that can describe the behaviour of a hydraulic damper with an adjustable nozzle, and that I can verify both through testing (if only I could figure out how – I’m thinking of measuring deceleration, or how time varies with and without damping, or simply by varying the flow cross-section) and using the simulation software I have available.
Because I still believe we can derive a relationship that actually describes what I can simulate using the software. For example, if I set a linear damping of 4 N/(mm/s), what does that correspond to in reality? What geometry would give me this approximate damping value? Or, conversely, given a geometry ‘x’, what damping value do I obtain? And how does it vary as the geometry changes?
Are these just observations I can draw from tests, or can I build a detailed mathematical model? And if so, how? What assessments would I need to make?
I imagine this isn’t something that can be developed straight away.
It's not clear exactly what you are trying to do, but it sounds like you are simulating a damper, then using the results to derive a damping coefficient. If so, damping coefficients refer to systems where the damping force is a linear function of velocity. Search term damping coefficient leads to many good sources. Air is more complicated than hydraulic because air is compressible.
When you do this with a linear law, you are defining the damping coefficient. You just need to work out the units. If the damping force is other than linear to velocity (such as quadratic), then the term damping coefficient no longer applies because the damping force is not a linear function of velocity.
If you are trying to simulate real world components, you absolutely positively need to start by measuring some real world components. You will quickly learn that the real world does not necessarily follow any simple model. Try searching shock absorber testing machine to learn more.
I'm thinking of a cylinder with a piston in which the clearance between the piston and the cylinder wall is finite. The piston is long, and the cylinder is oriented vertically, with a viscous liquid between the base of the piston and the cylinder. The length of the clearance between the piston and the cylinder wall is large, and, in addition to the liquid being present at the base, it also fills the length of the gas. You press down on the piston, and measure the force as a function of the piston when ward velocity.
You basically have pressure/drag flow between parallel plates, and can analyze the problem to get the piston pressure as a function of the piston velocity.
So, if I’ve understood correctly, I should first build a fairly realistic prototype without the hydraulics, test it, and then, once I’ve added the hydraulic components, assess the system’s deceleration and, based on that, determine a damping value?
Isn’t the use of simulation software or other computational methods sufficient on its own to derive an initial value to be tested subsequently using the prototype?
I mean software that allows me to carry out fluid dynamics analyses as CFD analyses.
The viscous damper I described in post #2 does not require CFD analysis to quantify its behavior. It can solved analytically for the damping force as a function of the piston velocity.
Are you willing to accepts this kind of device as a model for what your are trying to describe. What are your objective for this work? Are you just trying to get a better understand on how a damper might work, or are you actually trying to design a specific system to perform a specified function, and you need to be able to design a damper?
My suggestion is to do it Chet's way first. Before diving into a CFD. The more you understand the physics, the better your CFD model will be. I've seen spectacularly bad (though colorful) results.
The goal is to design the damper. But in order to do that, I first need to clearly understand what it actually implies, and above all the physics behind it.
My basic idea was to describe the relationships governing this phenomenon and to generalize them, not only for this specific case study.
So yes, as a first step, what I could do is measure the advancement speeds (or advancement times) at different settings of the adjustment nozzle and then extract a curve as a function of velocity. I assume that from this it should be possible to identify a trend.
I would first derive and solve the equations for the fluid dynamics of the system. Do you know how to solve axial annular laminar flow of a viscous fluid?
I should rewrite and simplify the continuity and momentum equations for the case at hand, probably reducing it to a two-dimensional problem.
I do not have the relevant ready-to-use equations in front of me, so I would need to sit down and derive them myself :)
Are you familiar with lubrication flow analysis? Do you know how to solve the problem of laminar flow between two infinite parallel plates?
Could you help me write out the system of equations?
Sure. But first, you need to show us exactly what you are trying to do. This requires a sketch. The sketch does not need to be a detailed engineering drawing. A simple pencil sketch that shows your concept is normally enough. Designs that look similar can have either laminar or turbulent flow, which makes a large difference in the calculations and the damping.
You need to specify what type of fluid because you mention both hydraulic oil and air in your OP.
I’ll try to attach a sketch.
It’s the simplest one I could think of, but it does represent what I’d like to model in physical terms. It shows a hydraulic circuit set in motion by an external force (spring, motor or ‘human power’).
By pulling the piston to the right, I move the fluid from the right chamber to the left one via the non-return valve on the piston (black path); conversely, by pushing the piston to the left, I move the fluid from left to right via the control nozzle (red path).
Obviously, the valve and the nozzle have different cross-sections and consequently the resistance coefficient is different. When the cylinder is pushed, the check valve is closed and so the fluid is forced to pass through the nozzle; when the piston is pulled, the fluid passes through the valve and not through the nozzle because of lower hydraulic resistance.
The fluid is hydraulic oil, and the question I would like to ask is how to evaluate the hydraulic resistance as a function of the variation in the nozzle cross-sectional area (velocity damping), and also to study this variation based on the flow cross-sectional area of the valve located in the piston.
I hope I have made myself clear and I have attached a very simple sketch. I hope it will be of help.
Many thanks to everyone!
Is this an existing physical piece of equipment that you can perform experiments on, or is it a schematic of a damping concept that you are analyzing and proposing to fabricate?
Let’s say it would be worth designing, even though such a system can already be found in many other applications. I would have the opportunity to build equipment to simulate this phenomenon and study it experimentally.
You have a hydraulic circuit with a flow resistance in one direction, and a different flow resistance in the other direction. Try search terms valve Cv or flow coefficient to learn how these flows are handled in the real world. The Cv is found experimentally, although you are free to try to derive it using CFD.
Knowing the Cv, the direction of piston movement, and the piston area, you can calculate the flow rate through the valve. From the flow rate and Cv, you calculate the pressure drop. From the pressure drop and piston area, you calculate the force on the piston. Damping is calculated from the piston force vs piston velocity. All of this is simple algebraic calculations that can be done using a spreadsheet or even a hand calculator.
Keep in mind the piston rod area and the effect on the system from the rod volume.
He almost has a shock absorber. Just need the spring.
