Proving the Equinumerosity of Infinite and Countable Sets
In summary, the discussion revolves around proving that the sets \mathbf{R} and \mathbf{R}-\mathbf{Q} have the same cardinality. One approach is to use the Continuum Hypothesis and argue that the cardinality of \mathbf{R}-\mathbf{Q} is aleph-1, the same as that of \mathbf{R}. However, this approach may not be satisfactory. Another suggestion is to explicitly construct a bijection between the two sets and visualize the situation better. It is also noted that |R\Q| = c, the cardinality of \mathbf{R}, and using the fact that the union of two countable sets is countable
soumyashant
Can you prove that [tex]\mathbf{R}[/tex] and [tex]\mathbf{R}-\mathbf{Q}[/tex] have same cardinality?
One way would be to say that [tex]\mathbf{R}-\mathbf{Q}[/tex] is not countable and must have cardinality <= [tex]\mathbf{R}[/tex] and invoke the Continuum Hypothesis to conclude that its cardinality is aleph-1 same as that of [tex]\mathbf{R}[/tex]..
Somehow this does not look appealing...
Can you explicitly construct a bijection and help me to visualise the situation better??
Thanks.
Well the union of Q and R\Q is R right? |Q| = \aleph_0 and |R| = c so if |R\Q| was aleph_0 then you have a contradiction i.e. isn't the union of countable sets, countable?
Yes, that proves that R\Q is not countable. But it does not prove that card(R\Q)= card(R). As soumyashant said, You would need the contiuum hypothesis, that there is no set of cardinality strictly between that of R and that of Q, to finish that proof.
Try to prove the following fact: If A is an infinite set and B is a countable set, then [itex]|A \cup B| = |A|[/itex]. You shouldn't need to invoke the CH.
Related to Proving the Equinumerosity of Infinite and Countable Sets
1. What is a bijection in mathematics?
A bijection is a mathematical function between two sets, where every element in one set has a unique corresponding element in the other set. This means that for every input, there is only one output and every output has a unique input.
2. Why is constructing a bijection important in mathematics?
Constructing a bijection is important in mathematics because it allows for a one-to-one correspondence between elements of two sets. This can be useful in proving the equivalence of two sets or solving mathematical problems involving sets.
3. How do you construct a bijection between two sets?
To construct a bijection between two sets, you need to find a function that is both injective (one-to-one) and surjective (onto). This means that every element in the first set must be mapped to a unique element in the second set, and every element in the second set must have a corresponding element in the first set.
4. Can a bijection exist between sets of different sizes?
Yes, a bijection can exist between sets of different sizes as long as the two sets have the same cardinality (number of elements). For example, a bijection can exist between the set of natural numbers and the set of even numbers, even though the latter is a proper subset of the former.
5. Are there any real-life applications of bijections?
Bijections have many real-life applications, including in computer science, where they are used in data encryption and compression algorithms. They are also used in economics to model one-to-one relationships between variables, and in statistics to establish a bijective relationship between two variables for regression analysis.
  • Differential Equations
