What does it mean for momentum to be a constant of motion?
  • Thread starter jus8727
  • Tags
    Motion
In summary, when momentum is a constant of motion, it means that the total momentum of the system remains constant and the time derivative of momentum is zero. This does not mean that there is no motion, but rather that the time-evolution of the motion does not change. To learn more, you can refer to the "Noether's Theorem" and related Wikipedia articles.
jus8727
what does it mean for momentum to be constant of motion.
i know that if it is it will commute with the hamiltonian but what does it mean in words?
If momentum is a constant of motion, there's a couple of things it means:
(1) momentum is conserved--the total momentum of the system (at least in the particular direction/angle) is constant
(2) the time derivative of momentum is zero ([itex]\dot{p}=0[/itex])--this does not mean there is no motion, just that the time-evolution of the motion is non-existent.
You should look at "[URL Theorem[/url] and http://en.wikipedia.org/wiki/Constant_of_motion" . These wiki articles might help you understand more.
Related to What does it mean for momentum to be a constant of motion?
1. What is the concept of constant of motion?
The concept of constant of motion refers to physical quantities that remain unchanged throughout a given process or system. These quantities are conserved and do not depend on the specific conditions or time frame of the process.
2. How do we determine the constant of motion in a system?
The constant of motion can be determined by using fundamental laws and principles of physics, such as conservation of energy, momentum, and angular momentum. These laws allow us to identify and calculate the quantities that remain constant in a given system.
3. What are the different types of constants of motion?
There are three main types of constants of motion: linear momentum, angular momentum, and energy. Linear momentum refers to the product of an object's mass and velocity, while angular momentum is the product of an object's moment of inertia and angular velocity. Energy can be either kinetic or potential, and both types are conserved in a closed system.
4. How does the concept of constant of motion apply to real-world situations?
The concept of constant of motion is essential in understanding and predicting the behavior of physical systems in the real world. It allows us to make accurate calculations and predictions about the motion and interactions of objects, such as in the fields of mechanics, astronomy, and engineering.
5. What are the implications of violating the constant of motion in a system?
If the constant of motion is violated in a system, it means that there is an external force or factor acting on the system. This can result in changes in the system's behavior and can have significant consequences, such as the destruction of a system or the failure of a machine. Violations of the constant of motion can also lead to new discoveries and advancements in the field of physics.
  • Quantum Physics
