Contradictions in Irrotational Vortex?
The discussion centers on the characteristics of Irrotational Vortices, specifically addressing the relationship between fluid velocity and distance from the vortex axis. It is established that in an Irrotational vortex, the fluid's flow velocity (u) is inversely proportional to the distance (r) from the axis, leading to varying speeds in adjacent streamlines. This variation causes friction and energy loss, particularly near the core, raising questions about potential contradictions in the physics of vortex behavior. The conversation concludes that while energy loss increases near the core, additional input energy is also required to maintain the vortex, illustrating a balance between friction and rotational dynamics.
  • Understanding of fluid dynamics principles
  • Familiarity with vortex behavior in classical physics
  • Knowledge of frictional forces in fluids
  • Basic concepts of energy conservation in fluid systems
  • Research "Irrotational Vortex Theory" for deeper insights
  • Study "Fluid Dynamics of Vortices" to understand energy loss mechanisms
  • Explore "Venturi Effect" and its implications on vortex behavior
  • Investigate "Coefficient of Friction in Fluids" for practical applications
Students and professionals in physics, particularly those focused on fluid dynamics, engineers designing fluid systems, and anyone interested in the principles governing vortex behavior and energy dynamics in fluids.
Stevenyzs
So I was reading about Vortices in Wikipedia, when I stumbled upon the explanation about Irrotational Vortices.
It states there that in Irrotational vortices, the fluid's flow velocity u, is inversely proportional to the distance r, from the vortex's axis.
Then, at the end of the explanation, it says that: "In an irrotational vortex, fluid moves at different speed in adjacent streamlines, so there is friction and therefore energy loss throughout the vortex, especially near the core." So the fluid's speed increases and decreases at the same time near the core/axis??
http://en.m.wikipedia.org/wiki/Vortex
Is that question meant in time or in space?
You need some external force to keep the fluid rotating.
Nah, I'm referring to general physics, not the space time stuff.
Like for example, when you whirl your hand in a bucket of water, you'll create an Irrotational vortex right? And the explanation provided by
Wikipedia first says that the fluid's speed in an Irrotational vortex is inversely proportional to the distance from it's axis.
It then proceeds to say that the different speed in adjacent streamlines, will cause friction between the streamlines, thus causing energy loss throughout the vortex, especially near the core/axis.
So isn't that a contradiction...?
Classical physics, sure.
There is a difference between "it gets hotter towards the equator" and "it gets hotter towards noon". So "it gets hotter" is ambiguous if you have both a space direction (towards/away from the center) and time (evolution of the system due to friction).
You have more energy loss near the core, so what? Your input power is also near the core.
A car on the highway has more friction and more speed than a car on other roads. Same comparison, no contradiction. The car on the highway just needs more gas.
So are you saying that the friction between the streamlines are somewhat constant, and more input energy is needed for a narrow Irrotational vortex...?
Constant in which aspect?
If that is the only difference: sure.
Constant, like the coefficient of friction mew, between the streamlines. Cos the more input energy you use to induce a faster vortex, the larger the frictional forces...right?
You have a fluid, friction in fluids is not a dimensionless coefficient.
Yes, the faster your vortex the larger your friction (in terms of power), similar to the highway&car example from above.
So for example, if I were to pass a vortex through a Venturi tube, would the rotational velocity increase due the vortex being closer to it's axis, or would the increase in frictional forces cancel it out?
That depends on details of the setup.
  • · Replies 24 ·
  • · Replies 31 ·
