Can Optimal Control Be Achieved Using Direct Cost Function Calculation?
The discussion revolves around the feasibility of achieving optimal control through direct calculation of a cost function, specifically the inner product between two operators in a quantum control context. The author is exploring gradient ascent methods and questions whether knowing the cost function directly could lead to a more efficient optimization of control variables. They express skepticism, suggesting that while the cost function indicates proximity to a solution, it does not provide directional guidance for updating control variables. The conversation emphasizes the mathematical nature of the problem, with a focus on the relationship between the operators and their optimization paths. Ultimately, the author seeks insights on formulating an algorithm under the assumption of direct cost function calculation.
Kreizhn
Hey everyone,
I have a hypothesis that I would like to confirm. I won't bore anyone with the nitty gritty details, so I will try to be as general as possible.
I'm doing a project on gradient ascent methods and their application to quantum control. The quantum part isn't important as my question is mathematical in nature, though a small caveat will appear and I'll make that clear.
Essentially, I'm trying to find an optimal control that will drive an operator \rho(t), \rho(0) =\rho_0 to an operator \tau in time T such that it optimizes their mutual inner product, say
C = \langle \tau , \rho(T) \rangle [/itex]<br /> The gradient ascent method says that we should find the gradient of C, and then proceed in the direction in which the gradient is maximal. This is very useful from a numerical standpoint, and that is the context with which I will be using it.<br /> <br /> I was asked during a seminar whether, in the event that we could directly calculate C, there was any way of formulating an optimal control just using the value of C, and if this could be potentially more efficient. Incidentally, this is where the quantum caveat occurs, in that there&#039;s no guarantee we can calculate C.<br /> <br /> Thus my question comes down to this. Under the assumption that we can calculate the cost function directly, can I then find an algorithm to optimize my control variables?<br /> <br /> I suspect not, since the inner product <i>naively</i> represents the overlap of the two operators. Hence calculating the cost function may tell us how close we are to a solution, but in an iterative numerical process, does not tell us &quot;in which direction&quot; to update our control variables.<br /> <br /> Any thoughts on this?
Mathematics news on Phys.org
I cannot see any changes in ##C##. If ##\rho## and ##\tau## are given, so is their angle ##C##. As I understand it, the control operator represents a path from ##\rho## and ##\tau## within the operator space, say ##\gamma(s)\,.## Thus you get angles ##C(s)=\langle \rho, \gamma(s) \rangle## which you could optimize.
However, a more specific answer depends on a more specific description.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
