Converge/Diverge: Show Work & Tests Used
  • Context: Undergrad
  • Thread starter Thread starter sdg612
The discussion focuses on determining the convergence or divergence of two infinite series, specifically involving trigonometric functions and alternating series. Participants are asked to show their work and state the tests and theorems used in their analysis.
  • Homework-related
  • One participant requests help with two series, expressing uncertainty about their convergence.
  • Another participant emphasizes the need for clarity in the expressions and encourages the original poster to show their work.
  • A participant suggests that the first series can be compared to a known convergent series, proposing that it converges based on the comparison test.
  • The same participant identifies the second series as an alternating series and applies the Leibniz rule to argue for its convergence, noting that the terms are positive and decreasing.
  • A later reply corrects the expression of the second series, indicating that there was supposed to be a 1 in the numerator.
Participants generally agree on the need to clarify expressions and show work, but there is no consensus on the convergence of the series as the discussion is still ongoing and corrections are being made.
The discussion includes missing assumptions regarding the convergence tests and the specific forms of the series. The correction to the second series indicates potential changes in the analysis of its convergence.
sdg612
Determine whether the following converge or diverge (show all work and state all tests and theormes used!)
a)[tex]\infty[/tex] (n=1)[tex]\sum[/tex]cos[tex]\hat{}[/tex]2 n/n [tex]\sqrt{}[/tex]n
b)[tex]\infty[/tex] (n=1)[tex]\sum[/tex]4(-1)[tex]\hat{}[/tex]n-1/n[tex]\hat{}[/tex]5+n[tex]\hat{}[/tex]3
i need help answering these 2 problems! any help wld be appreciated! Thnx!
Firstly, you need to show your work; we're not here to do your homework for you! Secondly, your expressions are not clear. Here, I'll rewrite them for you; click on the images to see the code:
[tex]\sum_{n=1}^{\infty}\frac{\cos^2n}{n\sqrt n}[/tex]
[tex]\sum_{n=1}^{\infty}\frac{4(-1)^{n-1}}{n^5+n^3}[/tex]
Are they the questions you are asking?
Finally, please be sure to post any further questions in the homework help forums.
Welcome to PF, BTW.
thank you! yes those are the questions! it took me forever just to get them looking like that! Thank you again I'm still trying to get used to this forum...
Hi, i suposse i would procceed in the following way:
Note that due to the fact that cos(x) is always smaller or equal than 1,
cos^2(x) has the same behavior. So, the sum that you are asking:
[tex]\sum_{n=1}^{\infty}\frac{\cos^2n}{n\sqrt n}[/tex] is smaller than
[tex]\sum_{n=1}^{\infty}\frac{\1}{n\sqrt n}[/tex] and this last converges
because it's a "p-type" sum with p=3/2>1. So by comparission, the first sum
must converge.
In the second one, you may see that it's an alternant series (the 4 doesn't matter)
and also that the sequence formed by the terms is a positive and decreasing one, so
due to the Leibniz rule (that applies only in this case) the sum is convergent.
Sory for the english i still don't know it very well
there was supposed to be a 1 in the numerator of the second sum...
  • · Replies 17 ·
