Convergence/Divergence of an Infinite Series
The discussion revolves around determining the convergence or divergence of the infinite series ∑(n/((n+1)(n+2))) from n=1 to infinity. Participants are exploring various methods to analyze the series within the context of calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants have attempted the comparison test and expressed uncertainty about its effectiveness, particularly in relation to the harmonic series. There are discussions about separating the series into partial fractions and the applicability of the limit comparison test. Questions arise regarding the implications of starting the harmonic series at different indices.
The discussion is ongoing, with participants sharing their thoughts and exploring different approaches. Some guidance has been offered regarding the limit comparison test, and there is a recognition that starting the harmonic series at a different point may not resolve the issue without additional considerations.
Participants are navigating the complexities of series convergence tests and are questioning the assumptions underlying their approaches. There is a noted lack of consensus on the effectiveness of the methods discussed.
Alex Myhill
To Determine Whether the series seen below is convergent or divergent.
∑(n/((n+1)(n+2))) From n=1 to infinity.
Tried to use the comparison test as the bottom is n^2 + 3n + 2, comparing to 1/n. However, this does not work as the first series is "smaller" than the harmonic series and thus it can't be proved to be divergent. I also tried to separate it into partial fractions but I don't know how to prove it is divergent from there. Thanks a lot for any help.
Is it still smaller if you start the harmonic series at six? And does this make the harmonic series convergent?
Have you seen the limit comparison test?
Also, this is definitely not a precalculus problem, so I have moved it to the calculus section.
Hi,
Thanks for the response. So to prove using comparison just start harmonic series at six. Makes sense, I hadn't thought of that.
Referring to Mark44's response, no, I haven't heard of the limit comparison test, however, I will look it up.
Thanks heaps for your time and input.
Alex Myhill said:
Hi,
I don't see how starting the harmonic series at six solves the problem, unless you also do some other things at the same time.
To me, the simplest solution is to note that for ##n \geq 1## we have ##n/(n+1) \geq 1/2##, so that
$$t_n \equiv \frac{n}{(n+1)(n+2)} \geq \frac{1}{2} \frac{1}{n+2}.$$
That means
$$\sum_{n=1}^N t_n \geq \sum_{n=1}^N \frac{1}{2} \frac{1}{n+2} = \frac{1}{2} \left[\frac{1}{3}+ \frac{1}{4} + \cdots + \frac{1}{N+2} \right] $$
  • · Replies 17 ·
