Convergence implies maximum/minimum/both
  • Thread starter Thread starter peripatein
    Convergence
The discussion revolves around the properties of convergent sequences, specifically whether a convergent sequence must have a maximum, minimum, or both. Participants explore the implications of boundedness and the relationship between the limit of the sequence and its supremum and infimum.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the definitions of maximum and minimum in the context of bounded sequences and question how to formally demonstrate that the supremum and infimum are close to the limit. There are inquiries about examples of convergent sequences and their properties regarding maxima and minima.
There is an ongoing exploration of the relationship between convergence and the existence of maxima and minima. Some participants suggest examining examples, while others express frustration over formal proof techniques. A few participants propose considering the contrapositive approach regarding sequences lacking maxima or minima.
Participants note the need for clarity on the definitions of supremum and infimum in relation to the limit of the sequence, as well as the implications of boundedness on these properties.
peripatein
Hello,
Could anyone please assist in proving that given a sequence converges it has a maximum/minimum/both?
I have hitherto written that granted it converges it must be bounded and have a supremum and an infimum. Now, how may I proceed to prove that the latter are indeed within (the neighbourhood) of the limit itself?
So if your sequence has a maximum, it is bounded above. If your sequence has a min, it is bounded below.
What do you know about a bounded sequence of real numbers?
What do you mean? I understand that any bounded sequence of real numbers must have a maximum and/or minimum, but how do I formally demonstrate that? Namely, how do I show that its supremum and infimum are within L, its limit?
peripatein said:
Hello,
Look at some examples of convergent sequences.
Does each have both a maximum and minimum?
Do all have only a maximum?
Do all have only a minimum?
Do they have to have at least one or the other?
Do any have both?
I can think of examples for sequences having either one of the two or both, but that still does not help me in formally proving the statement.
Do they have to have at least one or the other (minimum, maximum)?
Yes, they do.
How about proving the contra-positive, that a sequence which has neither a maximum nor a minimum does not converge?
I am still not sure how to formulate that mathematically. May you please advise?
if sequence an converges to A, then there exist N such that if n> N, |an- A|< 1 which is the same as saying A-1< an< A+1. Do you see how that gives upper and lower bounds for all an with n> N? And an for [itex]n\le N[/itex] is a finite set.
Naturally, but how do I use that to demonstrate that the supremum and infimum are within the neighbourhood of L.
This is very frustrating. I am still unable to prove that the supremum and infimum are within L. May someone please assist?
What do you mean by the supremum and infimum are within L ?
Hence, within L+epsilon and L-epsilon.
Where sequence converges to limit L.
  • · Replies 0 ·
  • · Replies 26 ·
