Convergent/divergent series problem
  • Thread starter Thread starter PaleRider
    Series
PaleRider
Determine whether the series is convergent of divergent. If it is convergent find its sum.
Ʃ (1+2^n)/(3^n) as n=1 to infinite.
I'm not exactly sure where to start with this. I tried to test for divergence but I don't know how to solve the limit. I tried to find a pattern with partial sums, but did not find anything relevant. Am I approaching this the wrong way? I kinda need a kick in the right direction.
EDIT: Was looking at the limit for test of divergence incorrectly. So now I know that the limit of an = 0 (after L'Hospital's rule and whatnot). Since an is convergent, I now must find the sum of the series...
How do you know the series converges?
I know the series is convergent because the limit of the series = 0. Test for divergence says that the series is divergent if the limit of the series does not exist, or if the series does not equal 0.
I made some more progress:
Ʃ (1 + 2^n)/(3^n)
= Ʃ 1/(3^n) + (2^n)/(3^n)
= Ʃ 1/(3^n) + Ʃ (2^n)/(3^n)
= 1/2 + Ʃ (2^n)/(3^n)
I'm not quite sure how to solve the remaining summation. Is it a geometric series?
Ʃ (2^n)/(3^n) = Ʃ (2/3)^n = 2
You may be misunderstanding. It is true that if the limit of the sequence \lim_{n\to 0} a_n is not 0 then the series \sum_{n=0}^\infty a_n cannot converge. But if the limit of the sequence is 0, then the series may or may not \onverge. \lim_{n\to 0} 1/n = 0 but \sum 1/n does NOT converge.
Ʃ (1 + 2^n)/(3^n)
\frac{2^n}{3^n}= \left(\frac{2}{3}\right).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
