Convergence of Series with Decreasing Terms: Can na_n Tend to Zero?
  • Thread starter Thread starter Treadstone 71
    Converging Series
Treadstone 71
"Suppose a_1\geq a_2\geq ... \geq a_n > 0 for all n such that \sum a_n converges. Show that na_n tends to zero."
The best I can do is prove that a subsequence na_n converges to a number between the sum of the series and 0.
The best I can do is prove that na_n converges to a number between the sum of the series and 0.
Have you tried assuming that na_n does not tend to zero and using a proof by contradiction?
Since the series converges, an converges to zero. If nan doesn't converge to 0, then that means that an converges to zero no faster than 1/n. But if an converges no faster than 1/n, then the series will be no "better" than than the harmonic series, and so it certainly will not converge - contradiction. This is the rough idea you might want to work with, but of course, it's not rigorous yet.
I thought about that approach, but the problem is that if it converges to a number less than 1, then I can't say that it the term a_n converges no faster than the harmonic series.
You can use the same idea. If it converges to some number c, such that 1 > c > 0, then an converges no faster than c/n, which means the series is no better than:
\sum \frac{c}{n} = c\sum \frac{1}{n}
I've gotten so far:
na_n is bounded, therefore has a convergent subsequence.
IF na_n converges, then it converges to 0.
All I have to do now is prove that na_n converges, which I am unable to.
Let's say you have some n_1
such that
n_1a_{n_1} > \epsilon
Can you give a (non-zero) lower bound on
\sum_{i=\frac{n_1}{2}}^{n_1} a_i
Now, if, in addition, you had
n_2 > 2 \times n_1
with
n_2a_{n_2} > \epsilon
can you give a lower bound on
\sum_{i=\frac{n_1}{2}}^{n_2} a_i
The lower bound for the first one would be the difference n_1a_n_1 - n_1/2 a_{n_1/2} assuming n1 is even. I don't see how this helps. Are you trying to show that na_n is Cauchy?
For an easy plug & chug way: apply the D'Alembert criterion (aka ratio test) on na_n.
The ratio test is for the series na_n, not the sequence na_n. The fact is that there exists converging a_n such that \sum a_n converges but \sum na_n does not. 1/n^2, for instance.
CASE 1:
Suppose {nan}n in N converges to some finite c > 0. Suppose that for all N > 0, there exists n > N such that nan < c/2. Well then {nan}n in N could not converge to c, countradicting our assumption. So there is some N > 0 such that for all n > N, nan > c/2. Thus we can choose a subsequence {nan}n > N which has each entry is at least c/2.
But then
\sum _{n \in \mathbb{N}} a_n = \sum _{n \in \mathbb{N}} \frac{na_n}{n} \geq \sum _{n &gt; N} \frac{na_n}{n} \geq \sum _{n &gt; N} \frac{c}{2n} = \frac{c}{2} \sum _{n &gt; N}\frac{1}{n}
But if the sum on the left converges, then it cannot be greater than the sum on the right, because the one on the right clearly diverges. Contradiction.
CASE 2:
{nan}n in N converges to some negative number. Impossible, since all the terms are positive. Contradiction.
CASE 3:
{nan}n in N diverges. Same argument as in Case 1. Contradiction.
CASE 4:
{nan}n in N converges to 0. By process of elimination, the only posibility, thus it must be the case. Q.E.D.
Let me try it this way:
What is the minimum value of a term in the sum.
How many terms are there?
AKG said:
CASE 1:
If it converges to any number, then I can prove that number must be 0:
na_n \rightarrow c &gt; 0 \Rightarrow \frac{na_n}{n\frac{1}{n} c}=\frac{a_n}{\frac{c}{n}} \rightarrow 1 \Rightarrow \sum a_n, \sum\frac{c}{n} converge or diverge simultaneously. Since \sum\frac{c}{n} diverges, so does \sum a_n, which is impossible.
However, na_n need not converge! All we know is that it's bounded, and therefore by Bolzano-Weierstrass theorem, there exists a converging subsequence. However, the above proof, using the converging subsequence, fails, since \sum\frac{c}{n_k} might be convergent, and thus not leading into a contradiction.
The problem with your proof is that I can't see how you can conclude for all n>N, since it should be a subsequence only.
How's this:
Assume, by contradiction that
\lim_{n \rightarrow \infty} na_n \neq 0
Then there is some \epsilon &gt; 0 such that for any n \in \mathbb{N} there is some N &gt; n such that Na_N &gt; \epsilon.
So, clearly there is an n_1&gt;3 so that n_1a_{n_1}&gt;\epsilon, and for any i&gt;1 there is some n_i such that n_i&gt;2\times n_i-1 and n_ia_{n_i}&gt;\epsilon.
Now \sum_{j=\ciel{\frac{n_i}{2}}}^{n_i} a_n &gt; \frac{\epsilon}{4}
since the sum contains at least \frac{n_i}{4} terms all greater than \frac{\epsilon}{n_i}.
Since n_i&lt;\frac{n_{i+1}}^{2} we have n_i&lt;\ceil(\frac{n_{i+1}}{2})
Now, we can regoup
\sum_{j=1}^{\infty}a_j \geq \sum_{i=0}^{\infty} \sum_{j=\ciel{\frac{n_i}{2}}}^{n_i} a_j &gt; \sum_{i=0}^{\infty} \frac{\epsilon}{4}
But this contradicts the assumptiont that the sum is convergent.
Hence the limit must be equal to zero.
Which is why I gave case 3.
What do you mean "all we know is that it's bounded." A priori, it might be unbounded, as it could be that an = 1. On the other hand, since we're asked to prove that {nan} converges to 0, we "know" that not only is it bounded, but that it converges to 0.
No, I started with:
which is:
(\forall N &gt; 0)(\exists n &gt; N)(na_n &lt; c/2)
I derived a contradiction from this, so I may infer its negation, which is:
(\exists N &gt; 0)(\forall n &gt; N)(na_n \geq c/2)
which is:
I know it's bounded because \sum_{1}^{\infty}a_i \geq \sum_{1}^{n}a_i \geq na_n &gt; 0 since a_n is decreasing.
AKG said:
CASE 1:
CASE 3:
I don't see how the argument from case 1 applies to case 3 since there is, by definition, no well-defined limit for a divergent sequence. Moreover, there are divergent sequences where there is no suitable c.
For example, consider that if a_n=\frac{||-1^n+1|+.5^n}{n}, then \left{na_n\right} is divergent since it has subsequences that converge to 0 and 2 (the odd and even terms respectively). For any finite c&gt;0 and any n \in \mathbb{N}, there is some n&gt;N so that na_n&lt;\frac{c}{2} since the odd terms converge to zero.
I
Sorry, case 1 doesn't exactly apply to case 3. It does to the subcase that the sequence diverges to infinity. In this case, pick any finite c > 0, and the same argument applies, but you'd replace "could not converge to c" in the second sentence with "could not diverge to infinity". However, case 1 doesn't apply to the subcase where the sequence neither converges nor diverges to infinity, but is simply bounded divergent (i.e., it "oscillates"). Note that Treadstone proved that the sequence is bounded, so we don't really need to apply case 1 to the first subcase of case 3 (the subcase where the sequence diverges to infinity), we can just say that this subcase will never happen
So, what to do when the sequence oscillates? Well, observe that:
\lim _{n \to \infty}\frac{(n+1)a_{n+1}}{na_n} = \lim _{n \to \infty}\frac{n+1}{n}\lim _{n \to \infty}\frac{a_{n+1}}{a_n} = \lim _{n \to \infty}\frac{a_{n+1}}{a_n} \leq 1
since {an} converges, which is true since the series converges. At least, I think that's correct. If it is, then I think it can be used to argue that {nan} in fact does not oscilate, thereby eliminating the remaining subcase of case 3.
A cleaner approach
na_n = \sum_{i=1}^{n} {a_n} \leq 2 \sum_{i=\lfloor \frac{n}{2} \rfloor}^{n}{a_n} \leq \sum_{i=\lfloor \frac{n}{2} \rfloor}^{\infty}{a_i} \leq \sum_{i=\lfloor\frac{n}{2} \rfloor}^{\infty}{a_i}
The \leq are justified because a_n is strictly positive, a_n is monotone decreasing, and a_n is strictly positive respectively.
Now we have
0 &lt; na_n \leq \sum_{i=\lfloor\frac{n}{2} \rfloor}^{\infty}{a_i}
Since the sequence converges, the limit on the R.H.S. as n goes to infinity must be zero. This bounds na_n above and below with sequences that go to zero, therefore na_n goes to zero.
I think you mean:
na_n\ =\ \sum_{i=1}^{n} {a_n}\ \leq\ 2\left ( \sum_{i=\lfloor \frac{n}{2} \rfloor}^{n}{a_n}\right )\ \leq\ 2\left ( \sum_{i=\lfloor \frac{n}{2} \rfloor}^{n}{a_i}\right )\ \leq\ 2\left ( \sum_{i=\lfloor\frac{n}{2} \rfloor}^{\infty}{a_i}\right )
Then applying the squeeze theorem (i.e. your argument) to:
0\ &lt;\ na_n\ \leq\ 2\left ( \sum_{i=\lfloor\frac{n}{2} \rfloor}^{\infty}{a_i}\right )
we get the desired result. Very nice!
Very clever. Thanks for the help!
