Converting this vector into polar form
4 replies · 3K views · last reply
Rodger125
TL;DR
I'd like to convert this surface velocity vector into the form I described. It might be just a matter of converting it into polar coords
In the following paper, the surface velocity for a moving, spherical particle is given as (eq 1):
$$\textbf{v}_s(\hat{\textbf{r}}) = \sum {2\over{{n(n+1)}}} B_n (\hat{\textbf{e}} \cdot \hat{\textbf{r}} \hat{\textbf{r}} - \hat{\textbf{e}}) P_n'( \hat{\textbf{e}} \cdot \hat{\textbf{r}})$$
where ##\hat{\textbf{r}}## is the preferred swimming axis (we consider that the sphere carries with it a fixed coordinate system that determines its preferred moving direction at each instant). ##\hat{\textbf{r}}## is a unit vector from the particle center to a point on the surface, we have the Legendre polynomials with $$P_n'$$ being the derivative of the n-th order Legendre polynomial, and $$B_n$$ is the amplitude of the corresponding mode.
They then (up to N=2) write the following expression for the surface tangential velocity, as a function of theta
$$\textbf{v}_s(\theta) = B_1 [sin(\theta) + {\alpha\over{2}} sin(2\theta)] \hat{\theta}$$
where $$\beta = B_2 / B_1$$.
How does one arrive at the second equation? Do you convert the first vector into polar coordinates? If so, how do you do this?
Thank you
I do not go into the mathematics but I am convinced that velocity of fluid at particle surface has no radial component. In fact
[tex]\mathbf{\hat{r}} \cdot \textbf{v}_s(\hat{\textbf{r}}) = \sum {2\over{{n(n+1)}}} B_n (\mathbf{\hat{r}}\cdot (\hat{\textbf{e}}\cdot \hat{\textbf{r}}) \hat{\textbf{r}} - \mathbf{\hat{r}}\cdot\hat{\textbf{e}}) P_n'( \hat{\textbf{e}} \cdot \hat{\textbf{r}}) =0[/tex]
where
[tex]\mathbf{\hat{r}}\cdot \mathbf{\hat{r}}=1[/tex]
where
That would make sense, I think. If we have a coordinate system moving with the sphere, and the sphere does not change in radius, surely the radial velocity would be zero
The authors describe the polar angle as
\hat r \cdot \hat e = \cos(\theta)
Therefore taking the sum,
\mathbf u^s (\hat r)=B_1(\cos(\theta)\hat r - \hat e)P_1^{'}(\cos(\theta))
+ \frac{1}{3} B_2(\cos(\theta)\hat r - \hat e)P_1^{'}(\cos(\theta))
with
P_1^{'}(\cos(\theta))=-\sin(\theta)
P_2^{'}(\cos(\theta))=-\frac{3}{2}\sin(2\theta)
The sum becomes,
-B_1(\cos(\theta)\hat r -\hat e)\sin(\theta) - \frac{1}{2} B_2(\cos(\theta)\hat r -\hat e)\sin(2\theta)
The result follows if
\cos(\theta)\hat r -\hat e=-\hat \theta
with
The sum becomes,
Thank you!
