Convolution of u(t) and cos(t)
  • Thread starter Thread starter Jncik
    Convolution
The discussion centers on the convolution of the unit step function u(t) and the cosine function cos(t), specifically the expression cos(t)*u(t). The participants analyze the integral representation of the convolution, leading to results that appear undefined. The confusion arises from the interpretation of the unit step function and its implications in convolution operations. Ultimately, the correct evaluation of the integral yields y(t) = sin(t), confirming that the convolution results in a well-defined output despite initial miscalculations.
  • Understanding of convolution in signal processing
  • Familiarity with unit step function u(t) and its properties
  • Knowledge of integral calculus, particularly improper integrals
  • Basic concepts of Laplace transforms and their application in solving differential equations
  • Study the properties of the unit step function and its role in convolution operations
  • Learn about the Dirac delta function and its relationship with the unit step function
  • Explore the application of Laplace transforms in solving convolution problems
  • Practice evaluating improper integrals involving trigonometric functions and step functions
Students and professionals in electrical engineering, signal processing, and applied mathematics who are looking to deepen their understanding of convolution and its applications in systems analysis.
Jncik
Hello, I'm revising this summer for signals and systems and I came across this convolution
cos(t)*u(t)
having two signals x(t) and h(t), where x(t) is the input signal and h(t) the impulse response
the output y(t) is given by y(t) = x(t)*h(t) = \int_{-\infty}^{+\infty}x(\tau)h(t-\tau)d\tau
cos(t)*u(t) = \int_{-\infty}^{+\infty}cos(\tau)u(t-\tau)d\tau (1)
u(t-τ) is 1 for t-τ>0 => τ<t
hence
(1) is
\int_{-\infty}^{t}cos(\tau)d\tau = sin(\tau)|_{\tau-&gt;t, \tau-&gt;-\infty} = sin(t) - sin(-\infty) = sin(t) - undefined in [-1, 1]<br />
now, I had 2 other integrals in the same exercise where the result was just sin(t), and I thought this was supposed to be sin(t) as well but I get this undefined number and I think it's wrong because I've never calculated an integral that gave me an undefined number, at least in signals and system course..
after searching in my book it had a similar integration
\int_{-\infty}^{+\infty}u_{0}(t)cos(t) dt
u_{0}(t) is just u(t)...
now again using the same method I would have
\int_{-\infty}^{+\infty}u_{0}(t)cos(t) dt <br /> = \int_{0}^{+\infty}cos(t) dt = sin(t)|_{t-&gt;0,t-&gt;+\infty} = sin(0) - sin(+\infty) = -sin(+\infty) <br />
which is undefined again
but he finds this result
\int_{-\infty}^{+\infty}u_{0}(t)cos(t) dt = \int_{-\infty}^{+\infty} \delta(t) dt = 1
I'm wondering, what am I doing wrong and why does he find such result?
thanks in advance
thanks in advance
Is that exactly what's written in the book? It doesn't look correct to me.
thanks for the reply
yes I'm using oppenheim's book(2.20 exercise) about signals and systems and I saw this at the solution manual.. I may be looking at the wrong exercise, but Now I'm looking at it again and I don't think so...
so is my solution correct on this one?
actually about u0
I don't see why he uses this '0' in the notation, if I remember correct when we have a system
y(t) = x(t)
if the system is not time invariant we use this notation in order to show that the impulse response for example h2(t) comes for input δ(t-2)
and hence the convolution would be
\int_{-\infty}^{+\infty}x(\tau)*h_{\tau}(t) d\tau
now I can't link these two facts for the notation he uses for u0.. but I don't think it affects the solution
It seems strange to me too. It feels like the result should be 0.
\int_{-\infty}^\infty u(t-\tau)*cos(\tau)d\tau=\int_{t-T}^t cos(\tau)d\tau=sin(t)-sin(t-T)=0
since
u(\tau)=0 \qquad \tau&gt;t
u(\tau)=1 \qquad \tau\leq t
T=2\pi
Sinus is periodical, that's why i integrate over one period instead of infinity. The
results should be the same = 0 for all periods.
Im not sure if I'm right. Anyone?
Maybe he have used distribution theory to solve that.
thanks, this looks correct to me.. but I'm not 100% sure either because
according to the solution, the integration of d(t) will give us 1...
Solutions aren't always right in books :)
I'm not 100% but if you think in the discrete case:
\sum_{m=-\infty}^\infty u(m)*cos(n-m)=\sum_0^{\infty} cos(n-m)=0
This sum will be zero for all n, since the cos function is symmetric around the x-axis. Equally amount of positive cos values as negative cos values.
Hmm... here's how I'd go about it -
y(t) = \int\limits_0^t h(t-\tau)q(\tau) \mathrm{d}\tau
where h(t) = 1 and the limits have been adjusted accordingly. Then,
y(t) = \int\limits_0^t cos(\tau)\mathrm{d}\tau Which of course leads to the simple integration of:
y(t) = sin(t)
Which seems a bit trivial... but, I think we can use the Laplace Transform to take a look at this as well. Both the FT and LT are used when looking at differential and integral equations, which I think this qualifies as. If we consider that the convolution in the time domain is the same as multiplication in the Frequency domain, then taking use of these LT pairs:
u(t) = \frac{1}{s} and cos(\alpha\,t) = \frac{s}{s^2 + \alpha^2}
Then simply multiplying these two:
Y(s) = \frac{1}{s} \frac{s}{s^2 + \alpha^2} = \frac{1}{s^2 + \alpha^2}
But since \alpha = 1 and the LT sin(t) = \frac{\alpha}{s^2 + \alpha^2} we can say that:
y(t) = sin(t)
I dunno... these are my thoughts. I definitely think your book's final last two terms for the answer are incorrect though.
How did you get u(t-\tau)=u(t)?
Of course Laplace is the best to use. Works every time :)
So true... *sigh* haha
But anyways, perhaps it'd be easier to think about getting the answer if we did the shifting in the cosine term:
y(t) = \int\limits_0^t cos(t - \tau)\mathrm{d}\tau
Now using a couple trig identities...
y(t) = \int\limits_0^t cos(\tau)cos(t) + sin(t)sin(\tau) \mathrm{d}\tau
y(t) = [cos(t)sin(t) - sin(t)cos(t)] - [0 - sin(t)]
Then things start canceling out all prettily...
y(t) = cos(t)sin(t) - sin(t)cos(t) + sin(t)
Yielding, once more:
y(t) = sin(t)Perhaps that's a little clearer? I'm not one hundred percent sure on this but the solution feels right and looks right at the moment, lol.
thanks that looks nice but I still have one more question
y(t) = sin(t)
since cos(t)*u(t) = \int_{-\infty}^{+\infty} cos(\tau - t)u(\tau) d\tau
and u(τ) is 0 for τ<0 shouldn't it be
\int_{0}^{+\infty}cos(\tau - t)d\tau = \int_{0}^{+\infty}cos(t-\tau)d\tau
my question is about this t instead of infinity that you have on your next post, how did you find it?
Well if you think about convolution - what it's doing graphically - you are shifting one of the waveforms over the other. This is the tau, but the 't' is the so-called 'limit' you're integrating to when moving one of the said waveforms across the other - presumably to infinity, which of course makes this system have an unbounded response as it should be.
If this is too vague let me know.
Jncik said:
actually about u0
y(t) = x(t)
I dug my old linear systems analysis book out of storage to refresh my memory, and I ran across this notation as well. In this convention, u0(t) is the Dirac delta function, u-1(t) is the unit step function, etc. In this light, that integral makes sense
\int_{-\infty}^\infty u_0(t) \cos t \, dt = \int_{-\infty}^\infty \delta(t)\cos t\,dt = \int_{-\infty}^\infty \delta(t)\cos 0\,dt = \int_{-\infty}^\infty \delta(t)\,dt = 1
Ecthelion is actually looking at the convolution of (cos t)u(t) and u(t). These one-sided functions are what you implicitly use when working with Laplace transforms. Using them avoids the difficulties you're running into, but it also means you're not solving the original problem as given.
Ahhh... I was not aware of that notation at all... definitely makes a lot more sense now, good find.
What do you mean with "implicitly use"? Laplace works for all t. (both sides)
And when you use a unit step u(t) the function y(t)=cos(t)*u(t) will be one sided?
Laplace transforms usually are defined with an integral from 0 to infinity. (See, for example, the second paragraph of http://mathworld.wolfram.com/LaplaceTransform.html.) Consequently, when you use them to solve a problem, you only find the solution for t≥0.
You could use the bilateral Laplace transformation. In that case, however, the transform
F(s) = \frac{s}{s^2+\omega^2}
for instance, corresponds to the function f(t)=(\cos \omega t) u(t), which is 0 for t<0.
