Cosmological expansion question
Invinoveritas
I am working off the premise that:
If Cosmological expansion is really occurring a redshift (as we currently observe) can only be obtained if (stars, planets, atoms) do not expand.
See Misner, Thorne and Wheeler comment:
"Only later does he realize that the atom does not expand, the meter stick does not expand, the distance between the sun and Earth does not expand. Only distances between clusters of galaxies and greater distances are subject to the expansion. No model more quickly illustrates the actual situation than a rubber balloon with pennies affixed to it, each by a drop of glue. As the balloon is inflated the pennies increase their separation one from another but not a single one of them expands!" [MTW, 1997, p.719].
I am looking for math or physics to justify this belief.
Thany you.
http://www.lightandmatter.com/html_books/genrel/ch08/ch08.html#Section8.2
See subsection 8.2.5.
Thank you for the link, I read the page and it does clear up some things, but brings up another question.
1. I don't see where they give the cause or the supporting data that universal expansion is not occurring.
Brooklyn may be expanding and if so it would not produce a red shift under the current theories.
Also
Barry Parker stated and John Peacock agreed that:
The redshift of galaxies exists because their light waves are stretched as space is stretched, and therefore their wavelength is increased"
If the expansion of space-time causes light waves to belengthened, why would atoms be excluded from this expansion?
There must be something that locally overcomes this expansion if Space-Time is truly expanding.
The article basically seems to say it is not because it cant.
There's a bunch of references listed at the end of this entry from the Usenet Physics FAQ, you could check some of those for the math.
The "something" that locally overcomes the expansion is the electromagnetic force and the strong and weak nuclear forces.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
