Could a magnetic charge make free energy?
The discussion centers on the potential implications of discovering magnetic monopoles and their ability to generate electric fields. It is clarified that while a magnetic field can create an electric current through movement, this process does not equate to free energy generation. The principle of energy conservation dictates that any energy produced will always be less than the energy input required to create that movement. The Biot-Savart law is referenced, indicating that it does not support the concept of free energy, whether for electric or magnetic monopoles. Overall, the consensus emphasizes that free energy remains a misconception in the context of electromagnetism.
Thesnake22
If or when magnetic charges (magnetic monopoles) are found, would a magnetic current create an electric field? If so, would you be able to generate an electric current with an applied field?
I would assume that was supposed to be
would a magnetic field create an electric current?
not sure where you are going with the magnetic monopoles
Other than that, the answer is yes... that's what happens in every generator that uses electromagnetism
But don't be fooled... as your title suggests ... there is NO SUCH THING as FREE ENERGY
you generate a current by moving a magnetic field around a stationary wire or visa versa
You MUST put energy into the system to make that movement of one or the other
and the amount of energy you create will ALWAYS be less than the energy applied
cheers
Dave
If you have a magnetic charge, would it be in reverse. Just like how a magnetic field would be created through an electric current, would an electric field be created through a magnet current (assuming there is magnetic monopoles to make a magnetic charge).
If you had magnetic monopoles then you could use Biot-Savart to calculate the electric field generated by a flow of magnetic monopoles.
Biot-Savart does not result in free energy for electric monopoles, so I don't know why you would think that it might for magnetic monopoles. In any case PMMs are a forbidden topic here.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
