Coulomb's Law/Electric field questions
  • Thread starter Thread starter krtica
    Field
The discussion revolves around solving problems related to Coulomb's Law and electric fields. The first question involves calculating the electric field and force on a proton due to two point charges, with participants suggesting plotting the points and using the Pythagorean Theorem for calculations. The second question addresses the speed of an electron in a weak electric field, factoring in gravitational force. Participants encourage sharing calculations to identify where the confusion lies. The thread emphasizes collaborative problem-solving in physics.
krtica
I am not sure how to approach any of these.
1- A 4.7-µC point charge is located at x = 0.9 m, y = 3.1 m, and a -3.9-µC point charge is located at x = 2.1 m, y = -1.9 m.
(a) Find the magnitude and direction of the electric field at x = -2.7 m, y = 0.9 m. magnitude:
direction: °
(b) Find the magnitude and direction of the force on a proton at x = -2.7 m, y = 0.9 m. magnitude:
direction: °
2- An electron is released from rest in a weak electric field given by = -3.00 10-10 N/C . After the electron has traveled a vertical distance of 1.9 µm, what is its speed? (Do not neglect the gravitational force on the electron.)
3- A fixed point charge of +2q is connected by strings to point charges of +q and +4q. Find the tensions T1 and T2. (Use q, d and k as necessary.)
T1 =
T2 =
Hi krtica! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help!
Start with 1(a). :smile:
tiny-tim said:
Hi krtica! :wink:
In regards to question 1, I plotted each point on a x-y coordinate system. The three points form a right triangle. The opposite and adjacent lengths I took for each separate electric field. To find the magnitude of both, I used the Pythagoreum Theorem.
Concerning the other questions, I am not really even sure where to begin.
ok, well, if it didn't give the right result, show us your calculations, and then we'll know how to help! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
