Coupled Oscillators Initial Conditions and Phase
1 reply · 3K views · last reply
yklin_tux
Hello I have a question about coupled oscillators and what initial conditions affect what constants of integration.
In the book I have, A.P. French Vibrations and Waves, the guesses at solutions are chosen at random and sometimes do include a phase shift, while sometimes they dont.
For solutions to a coupled oscillator example (two masses, three equal strings, no damping) there is a set of two equations
x1 = a*cos(w1*t+A1) + b*cos(w1*t + A2)
x2 = a*cos(w1*t+A1) - b*cos(w1*t + A2)
and this is based on the guess that one solution to the initial differential equation was of the form
x = C*cos(w*t + A)
I get why and how that is, but when assuming that the initial velocities are zero, the book just guesses at a solution of the form
x = C*cos(w*t), without the phase.
Which would give something of the form
x1 = a*cos(w1*t) + b*cos(w1*t)
x2 = a*cos(w1*t) - b*cos(w1*t)
I have to deal with a problem where I have initial values for the displacement, but the velocities are assumed to be zero.
Obviously, the first case, where there are phases, requires me to solve for 4 unknowns {a, b, A1, A2}
But if I use the latter case without A1, A2, the job is easier.
My question is, does the assumption that the initial velocities = 0 allow me to assume A1 = A2 = 0? and get rid of the phases?
Or is it incorrect for me to assume a solution in the form described above, without the phases present (i.e. I have to find A1, A2, from my initial conditions)
The book doesn't do a good job of explaining why they guess one solution with a phase and one without, so I sometimes get confused on that.
Cheers!
The book is not guessing that when the initial velocities are zero, the phases are zero. Starting from
and taking derivatives to find the velocities which you evaluate at ##t=0##, you get
##v_1(0)=-a \sin A_1-b \sin A_2=0##
##v_2(0)=-a \sin A_1+b \sin A_2=0##
If you add the equations, you get
##-2a \sin A_1=0##.
You have a product of three things that is equal to zero. This means that one of the following is TRUE:
1. ##2=0##, not a chance even for small values of ##2## :oldsmile:
2. ##a=0##, which is the trivial solution because it means there are no oscillations. :oldfrown:
3. ##\sin A_1 = 0## which implies that ##A_1=0##, yay! :partytime:
Similarly, by subtracting the equations you can show that #A_2=0##.
