Cramer's method for linear equations
Cramer's method for solving linear equations is discussed, focusing on the determinant calculations and the conditions for its application. The initial calculations yielded incorrect determinant values, leading to confusion about the necessary conditions for using Cramer's rule. It was clarified that the only requirement is that the determinant of the coefficient matrix must be non-zero, and there are no additional conditions that need to be satisfied. The discussion also suggests that for solving a single system of equations, simpler methods like elimination may be more efficient than Cramer's rule. Ultimately, the importance of accurate determinant calculations and understanding the method's requirements is emphasized.
lendav_rott
2x +5y -z = 3
3x + 5y -4z = -6 the bracket needs to go infront, so x,y,z satisfy all the equations at once.
4x -2y +6z = 1
Cramer's method:
(I don't know how to add certain symbols to the text so it is difficult to express it)
If A were the matrix of the coefficients of the variables then aij is a corresponding element and Aij = (-1)i+j * Mij - the subdeterminant? Is it the correct word? Mij is a minor of the corresponding element.
So Cramer's idea is this:
|A| = a11 * A11 + a21 * A21 + a31 * A31
and
a12 * A11 + a22 * A21 + a32 * A31 = 0
and
a13 * A11 + a23 * A21 + a33 * A31 = 0
I have no problem to solve this system, but the problem is:
I get the correct determinant value , but the following equations (which need to be 0) are not zero. Is Cramer's idea flawed? I am certain I have done the calculations correctly.
|A| = 2 * 38 - 3*28 - 4*15 = -68 good
5*38 - 5*28 + 2*15 =/= 0 not good
-38 + 4*28 - 6*15 =/= 0 definitely not good
I can also skip to the part where I replace the x,y,z coefficients with the numbers on the right side of the equal sign when I solve for x,y,z , but I am not so much interested in the solution, am I even allowed to do that operation when the requirements are not met?
I can also say for certain that there is a solution to it, because |A| =/= 0.
Well, for starters the determinant of your matrix is -100, not -68. Recheck your calculations, you've made a number of arithmetic errors. Also I'm not clear on what "the following equations (which need to be 0) are not zero" has to do with Cramer's rule. Where does Cramer's rule say those equations need to equal zero? The only requirement for the rule to work is the matrix have a non zero determinant.
Uhm I calculated and re calculated and recalculated this determinant a zillion times and I always got -68 , but now I got -100 :D
Right, so I messed up big time with that - to answer your question, though - Where does it say the other 2 equations need to be 0.
It doesn't say it directly, but it can be deduced -
What you have during the calculations is
|A|*x + 0y + 0z = s1 * A11 + s2 * A21 + s3 * A31 , where s ij is the vector of the solutions (3, -6, 1)
so if X, Y, Z were the matrices where the X, Y, Z columns have been replaced by the vector s then x = X/|A| and it won't work if the other mentioned equations aren't zero.
The part where I got confused is when I recalculated the thing a million times and didn't get the correct result and I got paranoid. So Cramer is right and I am drinking to my own stupidity tonight. I am sorry :(
EDIT:
Actually, hold up on that drink. When calculate the determinant with the Sarrus rule I do get -100. 60-80+6+20-16-90 = -100, BUT...
this a11 * A11 + a21 * A21 + a31 * A31 = -68 whereas it should be |A| = -100.
Am I calculating the subdeterminants correctly?
A11 = 5*6 + 2*4 = 38
A21 = -(5*6 - 2*1) = -28
A31 = 5*(-4) + 5*1 = -15
so by that |A| is 38*2 - 3*28 - 4*15 = -68
The rule by which I assume this to be correct is
nƩk=1 ak,i*Ak,j = |A| * δi,j where δ is the Kronecker's symbol, if i = j then δ = 1, when i =/= j, then δ = 0.
I am going berserk ...:/
I'm sorry, but I really don't understand what you're talking about. For starters, it will really help if you learn how to use this forum's LaTeX typesetting because your notation is pretty impenetrable.
In any case, there are no further conditions for Cramer's rule. All you do is compute the determinant, and then the determinants obtained by substituting each column with the desired solution. That's it. If you deduce any further "conditions" then they will be automatically satisfied for det(A) non-zero. I'm not sure what you're trying to do, but you are significantly over complicating this.
Okeeeey
Using Sarrus rule to calculate the determinants
|A| = -100
Ax = 219
Ay = -175
Az = -227
so by Cramer's rule:
x = 219/-100 = -2.19
y = -175/-100 = 1.75
z = -227/-100 = 2.27
Check 2x + 5y -z = 3?? => -2*2.19 + 5*1.75 - 2.27 = 2.1 ...not even close
However when I solve this system using the...invert matrix? A-1 * A * X = A-1 * S and using the determinant value of -68 when calculating A-1 elements from the...adjA. Adjugant matrix? Adjugate? :/ anyway, with the determinant value of -100 I end up in a brickwall, with -68 however, I get what I need. The reason why I am going berserk is what do I ultimately believe then?
I am not Trying to over complicate things, but the conditions I am talking about for Cramer's rule DO have to hold true. Otherwise such substitution is not allowed and that's why I am not getting the correct answers, because I have broken the rules if I just subsitute to the determinant in the manner as you described.
##|A_y| = -193##, which gives y=1.93. With this correct value, x,y and z do indeed satisfy the system of equations. You should practice calculating determinants since that is where your problem seems to lie.
I am digging my own grave already ...I am sorry, I don't know what's wrong with me today :/
lendav_rott said:
2x +5y -z = 3
4x -2y +6z = 1
Cramer's method:
and
and
Did somebody tell you that you must use Cramer's Rule? If not you should avoid it: it is just about the worst way to solve linear equations!
As I said, unless you are compelled to use Cramer, just use simple elimination methods: the first equation gives you z = 2x + 5y - 3. Substituting that into the other two equations gives you two new equations in the two variables x and y. Do the same type of thing again: use one of the equations to solve for one of the variables in terms of the other; for example, you can use the first of the two new equations to solve for y in terms of x. Substituting that expression into the other of the two new equations gives a single equation in the single variable x, which is easy to solve. Then substitute that x into the y-equation, etc.
If you are going to solve a single 3×3 linear system just once, this method is about as good as any; if you plan to solve a lot of 3×3 (or larger) systems manually, it is worth learning such methods as row reduction, etc.
