Create EMR at Long Wavelengths: Experimentally Possible?
  • Context: Graduate
  • Thread starter Thread starter flatmaster
The discussion revolves around the possibility of creating electromagnetic radiation (EMR) at long wavelengths through the oscillation of macroscopic objects. Participants explore theoretical aspects, experimental feasibility, and detection limits of such radiation, touching on various frequencies and antenna requirements.
  • Some participants suggest that moving charges create EMR, and theoretically, oscillating a charged macroscopic object could produce EMR, though the practicality of such an experiment is questioned.
  • There is a discussion about the challenges of detecting low-frequency radiation, with some stating that an antenna needs to be roughly the size of the wavelength for effective detection.
  • Others argue that smaller antennas can still receive signals, citing examples of portable radios that pick up signals significantly shorter than their physical size.
  • One participant mentions that submarines can receive extremely low frequencies (ELF) and proposes the idea of using large dipoles for interstellar communication, although this is noted as impractical due to the required size.
  • Concerns are raised about the efficiency of small antennas and the concept of "radiation resistance," which affects detection capabilities.
Participants express differing views on the effectiveness of small antennas for detecting long wavelengths, and there is no consensus on the feasibility of creating EMR with macroscopic objects or the specific detection limits involved.
Limitations include assumptions about antenna size and efficiency, as well as the practical challenges of oscillating macroscopic objects at required frequencies.
flatmaster
We all know you create E&M waves by spinning a dipole. Wether it's an AC current in an antena to produce radio waves, or an electrion falling to n=1 to produce an x-ray, moving charges create EMR.
That being said, theoretically, one could charge a macroscopic object, oscillate it extremely rapidly, and produce EMR. Has anyone done this experimentally? It's a rather silly experiment, but what would be the low frequency/long wavelength detection limit for radiation?
...in order to pick up the signal on a radio you would have to shake the macroscopic object back and forth over a millions times a second. That's sort of difficult with a *macroscopic* object.
As far as detection of radiation goes: as a rule of thumb, you need an antenna roughly the size of a wavelength to detect radiation (maybe a quarter wavelength, but that is the order of magnitude). As the wavelength increases beyond a few metres (frequencies < maybe a few MHz), it starts to get difficult.
Thats not entirely true. If we take a radio signal broadcast at 100 MHz then it would have a wavelength of 3m. Yet there are those very tiny radio's only a few centimeters long which manage to pick up the signal quite clearly? These are only around 1/1000 the length of the wavelength. I would say that it is less than this is where it gets difficult.
Then again this is only for radio where a loss of quality is accepted. So it only works if you can lose some of the data.
Submerged submarines receive signals as low as 76 Hz (ELF) and it has been proposed that huge wire dipoles could be floated in space in order to communicate over interstellar distances at a carrier frequency of 0.1 Hz. Bit science fiction as half wave dipoles would be 1.5 million km long and the data rate would be very very slow.
Short antennas don't receive well and portable radios working at 150 kHz - 1.5 MHz (AM bands) use ferrite rod aerials which are also not efficient.
The lowest frequency you are likley to receive at home is the 60 - 80 kHz (5000 - 3750 metre) signal for a radio controlled clock. These use ferrite rod 'magnetic...loop' aerials.
http://http://en.wikipedia.org/wiki/Communication_with_submarines" transmitters are used by the Navy to communicate with submarianes at sea.
You mean pulsars?
2ltben said:
You mean pulsars?
*who* means what?
I don't know about you, but my ears are nowhere near a half wavelength in dimension with respect to what "radiation" they can detect. :smile:
Look for info on "radiation resistance" to see why small apertures (<<wavelength) are not efficient antennas.
Regards,
Bill
  • · Replies 0 ·
  • · Replies 35 ·
11K
