Creating 300VAC for 3 Phase Variable Frequency Drive Testing
5 replies · 4K views
romo84
Hello all,
I have a 3 phase Variable frequence drive that requires an input voltage of 380-480VAC. I would like to test what would happen if I apply 300VAC to the drive.
I have access to 208V and 440V. Is there anything I can do to obtain 300V? I have thought about a variable power supply but at that voltage they are hard to find.
Thanks,
romo84 said:
Hello all,
Thanks,
Why can't you simply step down the 440V to 300V with a transformer?
Hi,
Because I cannot find a 480 to 300V transformer. Also would I need a transformer for each phase?
Yes you would need a transformer for each phase
If you stepped voltage down that way
How much current do you need?
Enough to run the motor, presumably tens of amps,
or just a few milliamps to fool some electronics into thinking power is pesent?
A good stereo audio amplifier IC and small 3 phase instrument transformer will do the latter.
Make two sinewaves 60 degrees apart and use them for open delta into step up transformer.
