Creating a galvanostat/potentiostat
  • Thread starter Thread starter DanTerp
The discussion focuses on creating a galvanostat/potentiostat for electrochemical impedance spectroscopy on Li-ion batteries. The project aims to either draw sinusoidal current or vary battery voltage sinusoidally, targeting a peak-peak current of ~100mA and a voltage of 25mV. Suggestions include using a digital rheostat or a Wienbridge oscillator, with an emphasis on developing a variable current source. A simple implementation proposed involves an op-amp current sink driven by a sine wave from a signal generator, with considerations for power dissipation and input bias. The conversation highlights the need for flexibility in design while maintaining simplicity for initial development.
DanTerp
Greetings!
I really would appreciate any insight regarding my project. I want to perform a form of electrochemical impedance spectroscopy on consumer electronic batteries (ie. measure the impedance of a battery - real and imaginary). Basically I want to create a device which is capable of doing one of two things:
  1. Draw current from a battery in a sinusoidal manner
  2. Draw current from a battery in such a way that causes the voltage of that battery to vary sinusoidally
The batteries I'll use are Li-ion (3.6V single cell - 4.2V fully charged). My target peak-peak current of 1) would be ~100mA. My target peak-peak voltage of 2) would be 25mV. Remember I only need to achieve one of these. I also want to be able to vary the frequency over a very small range (ideally 10Hz - 0.1Hz).
The ideas I've had so far are:
  • Use a digital rheostat (ie. constantly change the resistance value)
  • Use a fixed resistor with a wienbridge oscillator as a reference voltage
Of course I also need to measure the battery voltage and current. I would like to be able to measure to a resolution of ~250uV and ~1mA.
If you have any advice I would be grateful.
There are lots of ways to approach this. Basically you want a variable current source. (lookup current source on wikipedia) A current source can sink or source current depending on what you want to do. The complexity can range for a simple 1 transistor or FET source/sink to a digital to analog converter (most DACs are actually current DACs). With an opamp current source you can change the feedback such it becomes a voltage generator.
As for the source of your current waveform, it can range from the output of a sound card or portable device to a hardware variable frequency oscillator, to a uP that generates a sine wave or test signal digitally. A digital generator would also allow step or impulse changes, which can give very good information.
You may also want to characterize the battery with regard to accepting a charge.
What you are asking for covers a broad range of possible implementations depending on desired accuracy, flexibility, battery sizes, and your design skills.
meBigGuy,
Thank you for your post! Yes, I imagined there would be a plethora of possible implementations. My goal is to keep it as simple as possible, at least at the start.
It appears you have some experience in the area of battery characterization. Indeed it would be even more ideal to generate other signals (square wave, impulse, etc). In regards to the battery accepting charge, that also is me attempting to keep it simple. I would eventually like to have a device that does not need a power source, but instead is powered by the same battery on which it is performing EIS. In this case it would add complications storing energy to give back to the battery.
The batteries will always be single cell (nominal voltage 3.6V) with capacities of let's say 1000mAh to 5000mAh. For now I want to limit the device to a sinusoidal waveform. I want to be flexible on peak amplitude and frequency.
Would you be able to provide me with an illustration of your idea of the most simple implementation. Something I can get my hands dirty with as I converge to a more flexible and elegant design.
Daniel
The simplest, that is meaningful as well, would be an opamp current source/sink driven by a sine wave from a signal generator (possibly a sound card or mobile device like an ipod).
Assume only a current sink for the moment. A typical circuit would be one of many you can find with a google image search for opamp current sink. I'd recommend using a NFET as the output device. The wikipedia page for "nullor" describes what is going on.
Basically the sink circuit works by creating a voltage (based on the input) across a sense resistor to ground which causes the required current to be drawn from the load. For example, a 1V pk-pk sine wave across a 10 ohm sense resistor would cause a 100ma pk-pk sine wave.
The main practical problems are power dissapation in the output device and the input bias circuit.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
