Creating a Multi Bar Plot in Matlab with Zeros and Proper Legends?
  • Thread starter Thread starter madtraveller
    Matlab Plot
The discussion centers on creating a multi bar plot in MATLAB using a data frame representing different soil types and depths. The user faced issues with MATLAB not plotting zero values and improperly displaying legends. Suggestions included modifying the data to include small non-zero values or transposing the data frame, which ultimately resolved the plotting issue. However, the user still seeks a solution to ensure all x-axis labels are displayed correctly. The conversation highlights common challenges in data visualization with MATLAB and potential workarounds.
madtraveller
I have a 6 x 16 data frame "y" which stands for 16 different soil types at 6 different depth as followings
Code:
0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0
0	0	0	0	0	0.37	0	0	0.50	0	0.03	0.03	0	0	0.02	0.05
0	0	0	0	0	0.26	0	0	0.34	0	0.02	0.02	0	0	0.33	0.03
0	0	0	0	0	0.06	0	0	0	0	0	0	0	0	0.94	0
I'd like to create a multi bar graph which has 16 columns (soil type) and each column has another 6 sub column(6 soil depths). But it seemed that Matlab didn't like zeros value, thus it didn't plot it and I couldn't create a proper legend for it
Code:
figure;
% Legend for x-axis
soilType = {'S', 'LS', 'SL', 'SIL', 'SI', 'L', 'SCL',...
            'SICL', 'CL', 'SC', 'SIC', 'C', 'OM', 'W', 'BR', 'O'};
% Characteristics for legend
soilDepth = {'0-10cm', '0-100cm', '0-150cm', '10-40cm', '40-100cm', '100-150cm'};
bar(y, 'group')
set(gca, 'XTickLabel', soilType);
xlabel('Soil Type');
ylabel('Areal Fraction')
legend(soilDepth, 'Location', 'Northwest')
Any suggestion will be very appreciated. Thx
madtraveller
Take a look at this:
http://www.mathworks.com/help/techdoc/ref/bar.html
Assuming that your matrix is called yMat, you can use:
figure;
bar(yMat);
If that doesn't work, take a look at this:
http://compgroups.net/comp.soft-sys...-on-a-Bar-Graph-with-different-x-and-y-values
From what I got from that, you can create the following vectors: X = <1,2,..,16>, Y1, Y2, Y3, Y4, Y5, and Y6 (where each Y is a row). Then you can use:
bar(X,Y1)
hold on;
bar(X,Y2)
hold on;
bar(X,Y6)
and this should superimpose the bar graphs. The first method should work though.
Hi gb7nash,
The first suggestion is kind of identical to what I did and it didn't work
The second one didn't help either because what I need is to have 6 rows plotted beside each other with 6 different colors (16 columns x 6 color). In the end I will create a legend indicating 6 different color (soil depth)
Thx anyway
madtraveller
Dear all,
I still need help with this. The legend didn't display correctly with the above code and Matlab just plot the columns having non-zeros value instead of plotting all 16 columns
Thx in advanced
madtraveller
Maybe you could put a really small value in each column of one row? For instance, putting 0.001 instead of 0 for all the entries in the first row?
>> data(1,:)=0.001
A hack, but maybe just good enough to make your graph for you.
Hello MATLABdude,
I've just found out that you don't have to put small values at all. I just transpose my data frame "y" like this and it works nicely
Code:
bar(y', 'group')
However, the xlabel on x-axis still didn't display the way I want. Do you know a way to force all the labels show up on x-axis?
Thx
