Creating AC current from 6v DC source
The discussion revolves around generating AC current from a 6V DC source for a small electromagnet that requires reversing polarity. Participants explore various methods, including oscillators, antennas, and alternative power sources, while considering size and cost constraints.
  • One participant seeks a method to create AC current from a 6V battery for a small electromagnet, expressing concerns about the size and cost of available inverters.
  • Another participant inquires about the type of AC waveform needed, suggesting that the application may influence the design.
  • Some participants propose using oscillators, either built from OpAmps or passive circuits, to generate the desired AC signal.
  • There is a suggestion to consider creating an antenna sensitive to all frequencies as a potential solution for generating a dense band of frequencies.
  • A participant mentions the idea of using a miniature DC motor connected to a miniature AC generator, noting that while it could work, size remains a concern.
  • Another participant discusses generating white electrical noise and amplifying it to create an electromagnet with varying strength.
  • One suggestion involves using an MP3 player to generate audio signals with specific waveforms or frequencies, emphasizing the need for uncompressed audio to maintain signal integrity.
Participants express various methods and ideas, but no consensus is reached on a single solution. Multiple competing views and approaches remain present throughout the discussion.
Participants highlight limitations regarding size, cost, and the specific requirements for frequency generation. There are unresolved questions about the practicality and effectiveness of the proposed solutions.
Radiqua
Hello! I'm a long time reader, but this is the first time I've not been able to find the information I've needed already...
I have a small electromagnet that needs to have an AC current (it is essential that the electromagnet has a reversing polarity) but the source of power comes from a 6v battery.
I know I need an inverter, but all the inverters I can find are converting 12v to 220v AC - which seems to be slightly excessive (and expensive) considering that the electromagnet itself is no bigger then a penny.
Does anyone have any ideas? Is there something I can make myself, or something cheap that I can purchase?
I can use a 9v battery, if that's required, but everything about this project needs to be kept fairly small.
My knowledge of circuits and electronics is minimal, so please use small words (and maybe pat me on the head to tell me I'm doing a good job).
Many thanks!
What kind of AC current? Sinusoidal, or can you use other waveforms? What is the application?
Any kind of wave form is acceptable =).
The application is to have a bunch of these AC electromagnets with tuned resonate frequencies. The overall intention, is to have about 12 individual electromagnet + battery + resistors (to specify the frequencies) that are fairly small in size.
Any idea? I'm at a complete loss... its literally just the small scale that's making this impractical - the only power sources I can find that are small enough are always going to be DC =/.
Have you considered an oscillator? You can build them out of OpAmps or even passive circuits. Depending on the type of oscillator you can also filter the waveform to get just the fundamental frequency.
I googled "opamp oscillator" and this is the first to show up: http://www.ti.com/sc/docs/apps/msp/journal/aug2000/aug_07.pdf
Ahh, that looks interesting.
Will have to have an indepth read of that, thanks!
Does that mean I can run an oscillator through an electromagnet (as if the oscillator signal was a current) to make the electromagnet follow that signal?
I'll read up more on opamp oscillators now!
Another question though...
Is there a way of creating an AC electromagnet that carries a dense band of frequencies? Kind of like 'white noise' in the form of an electromagnet, if that's possible.
I'm not sure how to answer your question. It sounds more like an antenna than an electromagnet.
Haha! Thats a great idea!
And an antenna creates an electromagnetic field, so as long as I was able to create an antenna that is senstive to all frequencies, I'd essentially have what I'm looking for... I think. Maybe. Right...?
Thanks for your help! I'm going to do some research into antennas!
Silly suggestion...but you could take an old minature DC motor...hook it to a miniature AC generator...power the DC motor with your battery...and boom there you go as long as the frequency is within your specs.
Silly, I know...but technically it would work!
Radiqua said:
That would definitely work, but the problem would be size =/.
I found this, which would be perfect, and the only issue is shipping it to the UK (which is insanely expensive)
http://www.coolight.com/product-p/cl-iptc-3v-3-7ft.htm
...Or you could use that...sure! :)
Isn't that fixed a 3kHz? I thought you needed multiple/adjustable frequencies. If you need just one frequency and don't care what that frequency is, there's lots of CCFL backlight inverters.
You could generate white electrical noise and amplify it, then feed that to the solenoid to produce an electromagnet with randomly varying strength.
Buy a cheap MP3 player like a Sansa Clip that plays FLAC or WAV (or other lossless format), get some free audio synthesizer software or write a short program to generate audio files with whatever waveforms/mix of frequencies you want (within the audio range, anyway). If you want white noise, make a white noise track, want a frequency ramp, make a separate track for that. Two channels per player. Use a low-dropout 5V regulator to power them from the 6V via the USB interface, if their batteries don't last long enough and you can't find an actual 5V supply.
You want uncompressed or lossless audio, because lossy compression algorithms throw out a lot of the signal that you can't hear but which you might need. Even with this, keep in mind you're working with cheap audio hardware, not a precision signal generator. If it doesn't put out enough power, look into power amplifier circuits.
  • · Replies 31 ·
