Flyingwing12 said:
I got the small single wound job to spin continuously yes.
It has to be possible for this thing to spin.
I think I just need a very strong magnet.
You could try bar magnet(s).
And how would this commutator work? This keeps being mentioned and yet no one says how I should hook it up?
On DC motors, the function of the commutator is to allow current in only the rotor winding that is most effective in maintaining rotation
at that particular moment. In your egg whisk rotor, current in the upper wire is not aiding rotation (it's slightly opposing it), so allowing that current is counter-productive.
You could retrofit a commutator to your rotor (see my sketch). Cut the rotor wires near one of the hubs and rejoin each in a strong mechanical joint using heat-shrink tubing, while at the same time ensuring that there is no electrical connection inside that join. You have 8 wires, you need to cut and rejoin in a total of 7 places. (You could do 8, but 7 is exactly as good.) Perhaps include a tiny piece of matchstick inside the heat-shrink to keep the two ends of the wires apart.
You make this modification at only one end of the rotor wires, so that's 7 cuts-and-rejoins needed. This now means that electricity can't get into that end of the rotor via the axle, so remedy this with a flexible bare copper wire bent into a J-shape and positioned so it will make good contact with that end of the one rotor wire nearest the magnet. You can hold this sliding contact in your hand while you optimize its shape and positioning, for maximum rotational speed.
As I cautioned, if your egg whisk rotor shows no inclination to move, then increasing the current or adding a commutator will not change this.
Happy experimenting!
https://www.physicsforums.com/images/icons/icon14.gif
