Creating Wave Functions With One Variable: Can It Be Done?
7 replies · 2K views
johann1301
With the number i, its possible to create a wave function with just one variable.
example:
f(x)=i^x
or..
f(x)=2^ix
But is there any wave function without the number i AND with only one(x and y) variable? can this be created?
Hello,
Are you aware of the general equation of a wave?
Hint: (It is a second order differential equation)
example:
f(x)=i^x
or..
f(x)=2^ix
If you want something that oscillates, then something of the form r(x)e^(ig(x)) will give you that. A standard linear wave will be in the form g(x) = wx + c corresponding to a shift and frequency information and if you want a 'real' waveform with the same peak and trough for every wavefront then r(x) = c.
This expression will give you a complex wave-form with a real and imaginary component and if you want one or the other and not both you need to use the normal identities to get rid of the i term or the real term.
y = sin(x)
This is the same as
y=1/2 i e^(-i x)-1/2 i e^(i x)
so that would be "cheating"...
(ig(x))
does this mean i*g(x) (the imaginary unit times the function g of x)?
Hello,
I don't know anything about differential equations:(
