Formation of Stars: How Gas Spins to Fuel Birth
The spinning of gas in a forming star is not necessary for its ignition.In summary, stars do not require spinning gas in order to ignite. They come together and ignite due to gravitational collapse alone, and their spinning can actually interfere with the process. However, they can despin through magnetic braking.
Sniperman724
66
If a typical star is created by a spinning ball of gas, how does the gas start spinning in the first place to fuel that birth?
Astronomy news on Phys.org
Stars do not need to spin in order to ignite. They come together and ignite due to gravitational collapse alone.
A gas cloud is quite a large object and the slight difference in orbital speeds around the galaxy can be enough to impart a significant spin. But stars don't need to spin to form. Their angular momentum can actually interfere with the process of collapse, but they manage to despin by magnetic braking.
FAQ: Formation of Stars: How Gas Spins to Fuel Birth
1. How do stars form?
Stars form when a large cloud of gas and dust, known as a molecular cloud, collapses under its own gravity. As the cloud collapses, it heats up and begins to spin, forming a flattened disk shape. The gas and dust in the disk then clumps together and eventually becomes dense enough to ignite nuclear fusion, creating a star.
2. What causes the gas to spin in the first place?
The gas in molecular clouds can have small random motions, but overall it tends to rotate due to the conservation of angular momentum. This means that as the cloud collapses, the rotation speeds up, just like an ice skater spinning faster as they pull their arms in.
3. How is the gas able to fuel the birth of a star?
As the gas and dust in the disk clump together, they become denser and hotter. Eventually, the temperature and pressure in the center of the clump becomes high enough for nuclear fusion to occur, which releases a tremendous amount of energy. This energy helps to counteract the force of gravity and allows the clump to continue growing and eventually form a star.
4. Are all stars formed in the same way?
No, there are different processes that can lead to star formation. For example, low-mass stars like our Sun form from collapsing molecular clouds, while high-mass stars may form through the merging of smaller clumps or from the collapse of much larger gas clouds. Additionally, the exact details of the star formation process can vary depending on factors such as the temperature and density of the initial gas cloud.
5. How long does it take for a star to form?
The timescale for star formation depends on the size and mass of the gas cloud, as well as the environment it is in. Smaller, low-mass stars can form in a few million years, while larger, high-mass stars may take tens of millions of years. However, the overall process of gas collapsing and accumulating into a dense enough core to ignite fusion can take anywhere from tens of thousands to millions of years.
