Critically Stable - Control Theory
To determine critical stability in a third-order control system, it's essential to identify the conditions under which the system's poles are located on the imaginary axis. This typically involves adjusting the parameter K to ensure that at least one pole is at the origin while the others are in the left half-plane. The discussion highlights the importance of the transfer function's denominator, as its structure significantly influences stability analysis. Clarification on the definition of critically stable is sought, particularly its relation to eigenvalues. Understanding these concepts is crucial for successfully preparing for the control theory exam.
Delber
I am preparing for my control theory exam, but I have come across that I am struggling. I have a third order system and its asking to me determine when a value of an adjustable parameter, K for when the system is critically stable.
I just don't know what this corresponds two for a third order system. I know for a second order system it is when the dampening ratio is equal to one. Do I need to just find the value of K that places all the poles on the negative real axis?
Any help would be appreciated thanks.
Could you post the denominator of this transfer function? The number of terms in the Tx function can make a huge difference in the analysis. I almost suspect the function is of the form
s^3+s^2+s
which in that case you can factor out an s and all will be clear.
Can you define critically stable? is it associated with eigenvalue? when can i say the stability becomes crytically stable? i hope someone can help me to explain it, Thank You :)
