Calculate Torque on a Particle with Given Force and Position | Homework Solution
The discussion revolves around calculating the torque on a particle given a force and position vector. The force is specified as F = -11j N, and the position vector is r = (8i + 5j) m. Participants clarify that torque is calculated using the cross product of the position vector and the force vector, specifically r × F, which results in a torque of 0i, 0j, -88k. There is confusion regarding the sign of the torque, which should indeed be -88, and participants emphasize the importance of correctly applying the right-hand rule for cross products. The conversation concludes with a consensus on the correct method to calculate torque and the significance of vector notation.
sp3sp2sp
Force F⃗ =−11j^N is exerted on a particle at r⃗ = (8i^+5j^)m.
What is the torque on the particle about the origin? Express your answer using two significant figures. Enter coordinates numerically separated by commas.
F: 0i, -11j, 0k
r: 8i, 5j, 0k
F X r = (0-0)i - (0-0)k + (0 - -88)j
= 0, 0, 88
this is wrong because it should be -88, but I don't see why? It was my understanding that I should plug values into formula i - j + k. Thanks for any help.
F: 0i, -11j, 0k
r: 8i, 5j, 0k
= 0, 0, 88
What's the definition of torque?
F: 0i, -11j, 0k
r: 8i, 5j, 0k
= 0, 0, 88
In future, please avoid using symbols like j^N; in typewriter math, this means ##j^N##, which is not what you intend. Just use j N, or perhaps enclose the "N" in parentheses, so write either F = - 11j N or F = -11j (N). Better still, use LaTeX to typeset your formulas and equations, so you could write ##F = - 11\, j## N or ##F = -11\, j## (N). You could even make them look like vectors by using a bold font, or an arrow on top, like this: ##\mathbf{F} = -11 \, \mathbf{j}## N or ##\vec{F} = -11 \vec{j}## N.
Anyway, back to your question. Is torque equal to ##\mathbf{r \times F}## or is it ##\mathbf{F \times r}##?
Thanks for the replies . Torque is not communicative so torque = r X F
Its the cross product of the Force and the distance from pivot.
OK I think i get it now. it should be in form rXF which when you apply the i-j+k gives 0i, 0j, -88k
thanks for help
I am not familiar with such a formula. I assume it is some way to remember how to get the signs right, but if so I dislike it. It loses the symmetry.
It is really quite simple. The result is the next one around in cyclic order:
ixj->k
jxk->i
kxi->j
If you have to switch the inputs to get them in cyclic order, switch the sign too:
jxi->-k
kxj->-i
ixk->-j
Yup that's exactly what it was .. its not a formula, just way I was remembering it because it was confusing me. thanks for the help
