Understanding Cross Section in Physics: Dimension and Formula Explanation
The discussion centers on the formula for differential cross-section in physics, specifically its dimensional analysis. The differential cross-section, represented as dσ/dΩ, indeed has units of area, confirming its relation to surface dimensions. Participants question the dimensions of the variables involved, such as mi, mf, pi, pf, and T, and express confusion about achieving L*L in the context of the formula. There is also mention of the potential simplifications using natural units, such as setting c or ħ to 1, which complicates dimensional calculations. Overall, the conversation seeks clarity on the derivation and implications of the differential cross-section formula in physics.
naima
naima said:
Hi all
I found http://en.wikipedia.org/wiki/Cross_section_(physics)#Relation_to_the_S_matrix" on wikipedia:
{d\sigma \over d\Omega} = (2\pi)^4 m_i m_f {p_f \over p_i} |T_{fi}|^2
Has it the dimension of a surface? (I only see M*M)
It is the first time I read this formula about differential cross section.
Yes, the microscopic cross-section σ has units of area.
The differential cross-section is a measure of how the microscopic cross-section, σ, changes with respect to the solid angle, Ω.
Of course, but what are the dimensions of mi mf pi pf and T?
and how do you get L*L?
I am sure that there is a c = 1 or a hbar = 1 in this formula which disables one to do dimesional calculus.
Do you know how this equality is deduced?
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
