CRT direction of field in accelerating zone
In a CRT, the electric field direction is established by the positively charged plate at the front and the negatively charged electron source, resulting in a field pointing from front to back, or to the left when electrons are accelerated to the right. This leads to confusion about field lines, as they should point into negative charges, but the field experienced by the electrons is not their own. The acceleration of electrons is described by the equation F=ma=qE, with a textbook value of E given as 8.0 X 10^5 N/C. However, as electrons move closer to the field source, the distance (r) decreases, suggesting that the electric field strength (E) should vary. The discussion raises questions about how a constant E value can be applied when the field is expected to change due to the varying distance of the electrons.
acherentia
My textbook says that since the electrons are accelerated to the right in a CRT the field direction is to the left. This leaves me confused, because according to this model the field lines are pointing out from the electrons instead of pointing into the electrons. I thought that field lines are supposed to point into negative charge? Anyone can tell me where I go wrong?
The front of a CRT is essentially a positively charged plate, while the electron source is essentially a negatively charged point source, so the field direction is from front to back, which is to the left in the case you mentioned.
I keep forgetting that a charge cannot feel its own field, so obviously the field is not the electrons' field but a field that the electrons are subject to. Thank you.
How does the electric field produce acceleration in the moving electrons?
F=ma=qE?
My textbook gives a value for E CRT of 8.0 X 10^5 N/C. Which if this was a constant number, according to my calculations a=1.41 x 10^17 m/s^2.
But I also know that E=kQ/r^2. Since r is changing as the electrons are moving closer and closer into the field, so r is getting smaller and smaller, shouldn't the value of E be constantly changing.
If the value of E is constantly changing as electrons move closer to it, how did they come up with the number 8.0 X 10^5 N/C for E?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
