Current induced in loop as magnetic monopole passes
1 reply · 5K views · last reply
Dazed&Confused
Suppose a magnetic monopole [itex]q_m[/itex] passes through a resistanceless loop of wire with self-inductance [itex]L[/itex]. What current is induced in the loop?
[tex]\nabla \times \textbf{E} = - \mu_0 \textbf{J}_m - \frac{\partial \textbf{B}}{\partial t}[/tex]
[tex]\nabla \cdot \textbf{B} = \mu_0 \rho_m[/tex]
For a resistanceless loop [itex]\textbf{E}=0[/itex]. Thus integrating [itex]\nabla \times \textbf{E}[/itex], applying Stokes theorem, and then integrating over all time we have
[tex] 0=\int \oint \textbf{E} \cdot d\textbf{l} dt = -\mu_0 \int \textbf{J}_m \cdot d \textbf{a} dt - \int \int \textbf{B} \cdot d \textbf{a} dt = -\mu_0 q_m + \Delta \Phi[/tex]
where [itex]\Phi[/itex] is the flux due to the magnetic field.
No we have that [itex]d \Phi / dt = -L dI /dt[/itex] so that [itex]\Delta \Phi = - LI[/itex]. Thus we have [tex] -LI = \mu_0 q_m[/tex]
or
[tex] I = -\frac{\mu_0 q_m}{L}[/tex]
It just so happens that I have the solution. My answer is off by a sign. The method was outwardly similar, except there the left hand side of my equation was found equal to be [itex]-LI[/itex] by saying that [itex]-LdI/dt[/itex] was equal to the loop integral of [itex]\textbf{E}[/itex] and that the change in magentic flux was in fact zero as [tex] \oint \textbf{B} \cdot d \textbf{a} = \mu_0 q_m[/tex]
and that when the charge is far away (on either side) the flux through a flat surface will be zero so that the change is also zero. I cannot see why mine is incorrect assuming a resistanceless wire, but on the other hand I see that a zero change in magnetic flux must also be true.
It looks like your equation should be:
$$\frac{d\Phi}{dt} = L\frac{dI}{dt}$$
