Curve tangent is orthogonal to curve at a point
The problem involves a curve \( C \) that does not pass through the origin, with a point \( P \) defined as the closest point on the curve to the origin. The task is to prove that the tangent to the curve at point \( P \) is orthogonal to the vector pointing from the origin to \( P \).
  • Participants discuss the necessity of the conditions that the curve does not pass through the origin and that \( P \) is the closest point. There are inquiries about expressing the distance from the origin to points on the curve and the implications if the curve were to pass through the origin. Some participants explore the mathematical implications of the distance function and its extremum.
The discussion is active, with participants offering suggestions and exploring various interpretations of the problem. Some have provided reasoning related to the distance function and its derivative, while others are questioning the assumptions about the curve's properties. There is no explicit consensus yet, but productive lines of reasoning are being developed.
There are mentions of the curve needing to be differentiable everywhere and the implications of closure at infinity. The discussion also touches on the parametrization of curves by arc length.
mahler1
Homework Statement .
Let ##C## be a curve that doesn't pass through the origin and let ##P## be the closest point on the curve to the origin. Prove that the tangent to ##C## at ##P## is orthogonal to the vector ##P##.
The attempt at a solution.
Suppose ##P=\gamma(t_0)##, I want to show that ##<\gamma'(t_0),\gamma(t_0)>=0##. I am pretty lost with the exercise and I don't know why they mention the curve doesn't pass through the origin or the fact that ##P## is the closest point to the origin, are those hypothesis necessary?. I would appreciate some suggestions and maybe an intuitive idea of why these two vectors are orthogonal. By the way, in my class we are always working with curves parametrized by the arc lenght, so maybe I have to use the fact that ##|\gamma'|=1##.
How would you express the distance from the origin, O, to a point on C in terms of γ(t)? How would you then express the condition for an extremum of that function?
If C passes through the origin, where will P be? What meaning would you attach to the notion of a vector orthogonal to OP in that case?
The claim seems false to me. Don't you have to add that ##C## is closed?
If the curve passes through the origin which point is closest to the origin?
The points of the curve C are at some distance from the origin. P is the closest, that is, the distance between P and the origin is the shortest. You have to name a special point somehow...
The vector pointing to some point of the curve is ##\vec r(t) ## where t is the arc length. What is that distance of that point from the origin in terms of ##\vec r(t) ## ?
ehild
You would certainly need that it is differentiable everywhere and does not suddenly stop. Only needs to be closed if you count closure at infinity.
Following your suggestions (haruspex,ehild), the distance between any point of the curve ##\gamma(t)## and the origin is ##||\gamma(t)-(0,0)||##. At the point ##\gamma(t_0)=P##, this function has a minimum and as the norm is a monotone increasing function, I can look at the function ##||\gamma(t)-(0,0)||^2=<\gamma(t),\gamma(t)>##. Since ##\gamma(t_0)## is a minimum, then ##(<\gamma(t_0),\gamma(t_0)>)'=0##. But then## 0=(<\gamma(t_0),\gamma(t_0)>)'=<\gamma'(t_0),\gamma(t_0)>+<\gamma(t_0),\gamma'(t_0)>=2<\gamma'(t_0),\gamma(t_0)>##. From here it follows ##\gamma'(t_0)## is orthogonal to ##\gamma(t_0)##.
Is this correct?
Is this correct?
Add, that γ'(t) is tangent to the curve γ(t), so γ(t0)γ'(t0)=0 involves that γ(t0) is perpendicular to he tangent of the curve at point P.
ehild
Yes. I just wanted to rule out the possibility that the minimum occurred at an endpoint.
At the risk of being too obvious, say the planar curve ##\gamma(t) = (1+t, 0), \, t \in [0,1].##
