DC Capacitor-Inductor: Understanding Energy Storage & Current
  • Thread starter Thread starter Solmyros
    Dc
The discussion revolves around the behavior of capacitors and inductors in DC circuits, particularly focusing on energy storage, current flow, and the implications of steady-state conditions. Participants explore theoretical concepts and practical implications related to these components in electrical circuits.
  • Some participants assert that a capacitor acts as an open circuit in steady-state DC conditions, questioning how it can store energy despite having zero current.
  • Others explain that energy is stored in the electric field between the plates of a capacitor and that work is done to create this potential energy.
  • Participants discuss the transient period when current flows through a resistor while a capacitor charges, contrasting it with the steady state where current ceases.
  • There is a suggestion that the power of a capacitor in steady state is zero, as no work is being done when conditions are stable.
  • Some participants clarify that the ideal capacitor has no inherent polarity, while real-life capacitors may have polarity due to their construction, particularly electrolytic capacitors.
  • One participant raises a question about the application of Ohm's law in relation to energy stored in capacitors and inductors, noting that it does not apply in the same way as it does for resistive components.
  • There is a discussion about the interpretation of energy stored in reactive components and how it relates to potential energy in the circuit.
  • Participants consider the implications of steady state on circuit branches containing resistors and capacitors, suggesting that the resistor can be ignored when no current flows.
Participants generally agree on the behavior of capacitors in steady state and the concept of energy storage, but there are varying interpretations of how these principles apply in different scenarios, particularly regarding the implications of Ohm's law and the nature of energy in reactive components. The discussion remains unresolved on some technical details.
Limitations include assumptions about ideal components versus real-world behavior, the dependence on definitions of steady state and transient conditions, and the complexity introduced by AC circuits which are not fully explored in this discussion.
Solmyros
Ok i started working with capasitors and inductors and i have a question.
The capasitor is an open circuit to dc,right?
Now the questions:
a)If the current of capasitor is 0 how can it store energy?I know that we use this:1/2 C V^2 but it seems weird that with just stable voltage we store energy.
also
b)if in a branch we have a resistance and then a capasitor(and let's say the current goes from the resistance to the capasitor),the current that pass through the resistance is 0 as well because of the capasitor?
Now the questions:
Energy is stored in electric or magnetic fields. In a capacitor it's the electric field between the plates that stores the energy. In an inductor it's the magnetic field that surrounds the conductor that stores the energy.
also
In a circuit with a DC supply, the steady state condition (a long time after power is applied) is achieved when the capacitor has reached its final charge and potential difference. Current will have ceased by then. When power is first applied it will take some amount of time for the capacitor to charge through the resistor. During that period current will flow through the resistor. This period is also called the "transient period" (when things are changing) in contrast with the "steady state" when all changes have died away.
Any pair of conductors separated in space forms a capacitor, and to put some equal and opposite charge on each conductor takes work. That work is converted into electric potential energy in the capacitor.
For the second question, yes, a resistor connected in series with a capacitor wool admit no current under a static voltage load.
The AC/time-varying case is more complex.
So the power(if not called this way i mean work/time) of a capasitor in this steady state will be 0?
Also how the polarity of a capasitor is determined?
At steady state nothing is changing so the work being done must be zero, hence the power is zero also.
The ideal capacitor has no inherent polarity. It will happily accept potential differences of either polarity across its terminals.
Certain real-life capacitors rely on chemical films as their dielectrics (so called electrolytic capacitors for example) which can be sensitive to the applied polarity due to chemical reactions being driven by the potential. You only want to charge them with the specified polarity or risk the dielectric degrading and failing (with possible explosive force!).
Because the voltage across the inductor is 0,i suppose that the power is zero as well?
To get the amount of energy stored in a capacitor-inductor,we get E=1/2CV^2-E=1/2LI^2 respectively.So i suppose that ohm's law cannot be applied here cause if it were,the energy stored would be 0.What is the reason for this?
Sure.
Ohm's law applies only to resistance, not capacitance or inductance (until, that is, you get into the realm of AC circuits where reactive components have "impedance", but that's a tale for another day).
Why would you want to take the difference between the energies? They are both potential energy.
The energy stored in a reactive component isn't a signed quantity per-se. It's how that potential energy is made use of when its released back into the circuit that determines how you interpret its sign in your calculations. Usually one considers the total potential energy to be the sum of the stored energies, which may be a constant over time if there is no resistance in the circuit to dissipate energy.
Ok everything is clear to me now.Expect me if i face a problem about capacitors-inductor for AC circuits.
Hey.i have a question.
Lets say i am having a branch with a resistance and a capacitor.As we know the capacitor is an open circuit in "steady" state,right?
The question is what will happen to the resistance.I mean because of the capacitor,i erase the branch and everything it has with him?
Supposing that your branch consists of a resistor and capacitor in series, then at steady state there will be no current flowing through that resistor and no changes of voltage across the capacitor, so yes, then you can ignore the whole branch.
  • · Replies 16 ·
  • · Replies 18 ·
