DDWFTTW Turntable Test: 5 Min Video - Is It Conclusive?
  • Context: Undergrad
  • Thread starter Thread starter swerdna
    Test Turntable
The discussion centers around a test of the claim that a cart can travel directly downwind faster than the wind using only the immediate force of the wind, as demonstrated by a turntable setup. Participants explore the implications of the test results, the mechanics involved, and the validity of the DDWFTTW (Downwind Faster than the Wind) concept.
  • One participant describes their turntable and cart setup, claiming it ran against the motion of the turntable for over 5 minutes without losing speed, questioning if this is conclusive proof of DDWFTTW.
  • Another participant expresses skepticism, stating that the cart's ability to run against the turntable does not definitively prove DDWFTTW and suggests that proving the cart speeds up relative to the turntable would be necessary.
  • Concerns are raised about the potential role of lift in the cart's motion, with one participant suggesting that if the cart is speeding up, it could be due to lift rather than additional speed.
  • Some participants note that the cart does not gain thrust from being held against the moving surface, but rather from the wind created as it moves through still air.
  • There is a discussion about the airflow generated by the turntable and its possible effects on the propeller, with one participant suggesting that the airflow from the spinning table might be contributing to the propeller's thrust.
  • Another participant questions whether friction at the pivot point could be affecting the cart's speed relative to the turntable, suggesting that this might create a relative speed that allows the propeller to generate thrust.
  • Several participants express interest in the design and concept, with one suggesting the potential for commercializing a small model of the device.
Participants express a mix of skepticism and intrigue regarding the DDWFTTW claim. There is no consensus on whether the test results provide conclusive evidence, and multiple competing views regarding the mechanics at play remain unresolved.
Participants highlight various assumptions about the mechanics of the setup, including the effects of lift, airflow, and friction, which are not fully explored or resolved in the discussion.
  • #811
schroder said:
After the initial transient, the cart will move along with the TT in the same direction for a brief time.
Now, do you agree, or not, that at that point (when the cart is moving (almost) simultaneously as the TT), the wheel is (almost) not turning, and that if the cart were running completely in sinc with the TT, that the wheel would not turn at all ?
It begins by moving at exactly the same speed as the TT and the linear velocity on the edge of the wheel is the same as the linear velocity on the surface of the tread.
The linear velocity of the (bottom of) the wheel will ALWAYS be the same as the linear velocity of the surface of the TT at that point as it isn't slipping.
Important to note here that the wheel is rolling on the TT surface, it is NOT glued down or flat or any other silly supposition as Vanesch has offered up!
In the beginning it is rolling *very slowly* and that is because it is not following *completely* the TT. If it were, the wheel wouldn't turn. As if it were glued.
As if it were a bicycle standing on a truck, while the truck is driving. The wheels of the bicycle don't turn (or do they ?).
Air resistance to the cart, mainly the propeller as well as the crossarm will cause the cart to slow down in the direction of the TT.
Yes, and as the difference in velocity is increasing, the wheel is rotating faster and faster.
This is the CRITICAL point! As the cart’s motion from Right to Left slows, it’s RPM on the TT slows also!
You are talking about the RPMs of the wheel, right ?
It is of course increasing, from almost 0 (and would be perfectly 0 if the cart were following perfectly the TT), to a rotation rate which is exactly that of a wheel held fixedly by a bystander and letting it roll on the TT when the direction of the cart turns over, that is, when, in the ground frame, it flips from going in the direction of the TT, to the other direction.
Some of the rotational motion is being exchanged for translational motion! This is the classic heterodyne.
You are confusing again kinematics and dynamics. And btw, no need to bring in a heterodyne ; Lagrange or Euler would have been totally capable of solving the mechanics of this thing, and had never heard of a heterodyne. So leave that out here. You don't need the concept of a heterodyne (and I don't see how it can be useful but that doesn't even matter) to do mechanics.
Now, we enter the final stage, where the cart has slowed down enough to a steady RPM which is less than it had when it was moving Right to Left. The cart has slowed enough that the translational motion causes it to move from Left to Right. This is where everyone believes the cart has outrun the TT and you want to add the velocities as relative velocities to arrive at a cart velocity which is greater than the TT velocity.
Yes, because in order to do so, you have to run even faster backwards.
Imagine that you are going to a childrens' manège (ride in english ?). You put your kid on a horse (bolted) on the manège while it is still not turning. Your other child is standing still, outside. While you are still on the manege with your first kid,it is starting up, and it starts turning CW. In the beginning, you remain steady with your kid on the horse. 1) ARE YOU WALKING NOW ?
Next, you want to keep up with the kid outside. 2) ARE YOU SLOWING DOWN OR SPEEDING UP to keep level with the kid outside as compared when you were with the kid on the horse ?
The kid outside wants to play a trick on you, and runs CCW AGAINST the CW direction of the manege. You want to keep at his side. 3) SHOULD YOU RUN FASTER OR SLOWER TO KEEP UP WITH HIM than when the kid was still standing still ?
Answer these 3 questions in upper case, please.
We can go further. Imagine that the outside kid wants to keep up with his little brother on the horse (bolted on the manege). Should the kid:
a) stand still
b) run CW around the manege which is turning CW
c) run CCW around the manege which is turning CCW ?
to keep at the same place has his little brother ?
  • #812
The wheel is rotating slower and slower.
I will not leave the heterodyne out of here because this is a heterodyne problem!
Your example has nothing to do with a heterodyne, it is an example of relative velocities which has nothing to do with this problem. NOTHING to do with this problem!
I suggest you let Swerdna do his test and I do suggest you study up on heterodynes as you clearly do not understand anything I am saying. Sure, LaGrange and Fourier could have solved this, but you are neither! Fourier understood heterodynes very well btw! Ever heard of Fourier transforms and Bessel functions?
  • #813
Ok, back to the floor as a frame of reference.
Again using the floor as the frame of reference.
As the cart’s motion from right to left slows, it’s rpm on the TT slows also!
As the difference in speed between cart and TT increases, so does the rpm of wheel and prop. I've been considering right to left as negative and left to right as positive, and CW angular speed as positive. The angular speed of the wheel in radians / unit time = (cart speed - TT surface speed at wheel) / (wheel radius). Some example states using swerdna's cart, wheel radius = 4.25 cm:
cart speed = -10 m / s
tt speed = -10 m / s
w = ((-10) - (-10)) / (4.25) = (0 / 4.25) radians / sec
cart speed = -5 m / s
w = ((-5) - (-10)) / (4.25) = (+5 / 4.25) radians / sec
cart speed = 0 m / s
w = ((-0) - (-10)) / (4.25) = (+10 / 4.25) radians / sec
cart speed = 2 m / s
w = ((+2) - (-10)) / (4.25) = (+12 / 4.25) radians / sec
  • #814
We ARE talking about relative velocities. You were the one saying that the relative velocity between both is 8, and not 12 m/s (or mph whatever). It is ALL about relative velocities.
Sure. We'll have a good laugh at you then.
I don't understand much of what you are saying, that is correct. The things I understand are so full of elementary errors that I can't make head or tails of it.
I wasn't talking about Fourier, I was talking about Euler. Yes, I've "heard about Fourier transforms and Bessel functions" :smile:
I will tell you where your "equivalence" with frequency mixing goes wrong: there are no negative frequencies (well, there are, of course, in a Fourier analysis, but when you're doing a frequency transformation in a radio receiver, only positive frequencies count). This is why, when you try to do vector addition in the frequency domain the way you are trying to do an analogy here, you mix up all your signs.
The idea of frequency shifting (heterodyning) is that you apply the sum of two sine functions to a non-linear element which includes a quadratic term:
s1(t) = sin(a t)
s2(t) = sin (b t)
f(t) = (s1(t) + s2(t))^2 = s1^2 + s2^2 + 2 s1 s2
The trick is that as such, the product between s1 and s2 appears.
Now, we have the identity sin(u) sin(v) = 1/2 cos(u-v) - 1/2 cos(u+v)
That means that the "sum frequency" and the "difference frequency" appears somewhere.
Now, imagine that we have a frequency of 10 MHz, and we mix it with a 2 MHz signal: we will obtain, in our output, an 8 MHz signal and a 12 MHz signal of course.
However, this is the trick: there's no such thing as "mixing with a -2 MHz signal"... This is just a 2 MHz signal with eventually a phase shift. So you can't "mix with a -2 MHz signal.
You don't see the difference between mixing 10 MHz and 10 MHz, or 10 MHz and "-10 MHz".
In other words, heterodyning is not a good analogy to learn about the behaviour of the addition of negative and positive numbers, and that is what you want to do here.
This thing has absolutely nothing to do with heterodyning, or with frequency mixing, or whatever. It is a relative velocities problem. You pulled in the concept of heterodyning. I could pull in Feynman diagrams, or transactional analysis, or any other unrelated thing. That doesn't change anything about this basic problem.
So could you answer the 3 questions on the children's manege ?
  • #815
shroder your problem seems to be that you do not understand the concept of inertial frame of reference. As Jeff Reid pointed out you were comparing velocity relative to the floor when you should have been measuring the velocity of the cart on the turntable.
In the beginning the velocity of the cart is zero relative to the turntable. That is when you observe the cart moving CW with the turntable. At this point the wheels are not rotating at all. When the propeller starts to turn the cart moves forward relative to the turntable, it is still going slower than the turntable so from above we can still see it moving clockwise, but it moves slower than the turntable.
It eventually is moving just as fast as the turntable, at this point it is stationary with respect to the ground, but the frame of reference that matters here is the one relative to the turntable.
Finally the cart is moving faster than the treadmill, from above it is seen to be moving backwards. Again you have to be aware what frame of reference in which you are measuring the carts speed. If you had a speedometer on the carts wheels you would see that it had a higher speed than the speed of the treadmill when measured from the ground. It might be a little tricky to see what is being modeled here because you are looking at different frames of reference to understand what is happening, but is not really all that difficult.
Lastly the only references I can find for heterodynes refers to radio waves, and has nothing to do with mechanical motion at all.
  • #816
vanesch, you were describing a "merry go round". Big ones at fairs are powered by a motor of some sort and the horses go up and down, the small park ones are hand pushed and may have horses or just a platform to sit or stand on with some bars for gripping or pusing.
  • #817
Subductionzon said:
Finally the cart is moving faster than the treadmill.
The direction of treadmill opposes the direction of the cart. The cart is never "faster" than the treadmill if it's direction opposes that of the treadmill. If you're referring to magnitudes of speed, you need some frame of reference. Using the floor as a frame of reference (schroeder's choice), the cart's magnitude of speed never exceeds that of the treadmill with the current carts. The cart advances 1 revolution for each time the turntable retreats 2.33 revolutions. Relative to the treadmill or to the floor, the cart speed is greater than the wind speed. I've previous restated the claim as:
|cart_speed - treadmill_speed| > |wind_speed - treadmill_speed|
in order to eliminate any frame of reference issues.
  • #818
Yes, I could have worded that a bit better. Let's just say that the speed of the cart measured from its wheels is faster than the speed of the turntable with respect to the ground. It can be a bit tricky when you are comparing various frame of reference. And of course at this point the cart is faster than the modeled "wind".
  • #819
schroder said:
Since the TT is a circular device, I suppose there is room for confusion. Your drawing is correct in a frontal view of the TT and the cart is running on the front edge closest to the viewer. In the video I saw, the cart began translating while it was running on the back edge, farthest from the viewer. In that frame of reference, the TT is turning CW, the edge of the TT is moving from Left to Right, the cart is moving from Right to Left and the wheel is turning CCW. Correct?
That’s a disappointing answer but let’s move on.
To keep this as simple as possible let’s forget about directions and the prop and just consider what’s happening between the TT surface and wheel. The TT has one motion in one direction and this motion gradually increases until it reaches a terminal speed. The wheel has two motions - the motion of the wheel as a whole with or against the motion of the TT (motion of the axle) and the motion of the wheel around the axis of the axle (revolving).
(1) If the axle of the wheel is traveling at the same speed and in the same direction as the TT, then the wheel doesn’t revolve.
(2) If the axle of the wheel travels at a different speed than the TT (faster or slower), then the wheel revolves.
(3) The greater the difference in speed between the axle and the TT, then the greater the speed that the wheel revolves.
(4) In the video the difference in speed between the axle and the TT surface gradually and constantly increases until the axle reaches a terminal speed in the opposite direction from the TT.
(5) As the difference in speed between the TT surface and the axle constantly increases (see 4) then it follows that the speed of the wheel’s revolution also constantly increases (see 3).
If “rotating“ means the wheel revolving about it’s axis your claim that “The wheel is rotating slower and slower” is obviously incorrect. Even if by “rotating” you mean the motion of the axle then you are still incorrect. For the wheel to rotate (revolve about it’s axis) slower and slower then the difference in speed between the TT and the axle has to become less and less. Please explain where and when this happens in the video - http://nz.youtube.com/watch?v=MCB1Jczysrk.
  • #820
Yes, thanks, that was the word I was looking for. I wanted an abstract merry go around in which there are no superfluous movements of horses going up and down..., but powered by a motor of course...
  • #821
Prop car vs sail cart rules schroder. ??
Looks like the tag line might have to change to "the race that schroder suggested and then dropped because he's afraid of the results".
JB
  • #822
ThinAirDesign said:
Ok, fair enough. Convince me that the outcome of a "Bernoulli vs Newton" argument somehow alters the outcome of a DDWFTTW argument and I will engage.
You and Jeff never address the low pressure (favorable to the cart) that is created in front of the prop. Without trying to sort out if that is a Bernoulli, Venturi, or Coanda effect, it remains low pressure, and can only be contributing to the force the prop exerts on the cart.
Jeff outright dismisses the importance of this contribution , claiming it all ends up as "slowed air" in the end, and you don't address it at all, focusing instead exclusively on the air that is compacted behind the prop as the only operative force on the prop:
ThinAirDesign said:
The prop is able to do this because it's operating in such a favorable environment -- a tailwind.
Let's take a well known type certified combo (Cessna 172, Lycoming engine, Sensenich prop) and add only one variable ... tailwind. Tie the plane down and instrument with load cells for thrust and you'll find that of course with a tailwind there's a lot more thrust for a given horsepower than in still air. No mystery there.
Same with the cart prop -- it's working in a very favorable environment and thus doesn't have the same horsepower requirement to generate the needed thrust to move the cart forward as it would in still air.
I've done a little googling and find that the faster, lower pressure air on the front surface of the props blades does not slow down upon meeting the slower air behind the blades, it reacts by forming a vortex with that slower air, which is shed as the blade tip vortex. The lower pressure at the front surface of the blades, therefore, represents a net forward pull on the prop which is automatically applied to the cart body. This forward pull when taken into account gives the cart more momentum than when you only consider a Newton III push from behind.
I do not understand why you guys ignore something so favorable to your argument. It is only when I consider the potential contribution of the forward pull that the cart seems like it might work as claimed.
  • #823
If I have not addressed it (and I'll take your word for that), it's because it's SOP relating to basic prop operation. I know for a fact I have stated (but perhaps on other threads) that the definitive characteristic of a prop (vs turbine) is that it moves air from a low pressure region to a high pressure region.
So, in short a prop functions not just by creating a high pressure area to the rear, but also an associated low pressure area to the front. It's the combo that does the trick.
Absolutely agree and would be surprised if you could find something that implies I feel differently.
Jeff outright dismisses the importance of this contribution , claiming it all ends up as "slowed air" in the end, ...
Can't speak for Jeff, but if that is his position, I disagree. The prop behaves no differently when installed on the cart than it does when installed on the RC Cessna for which it was designed. I would be very surprised if Jeff feels that there isn't a low pressure in front of a Cessna's prop influencing the motion of the plane.
... and you don't address it at all, focusing instead exclusively on the air that is compacted behind the prop as the only operative force on the prop:
Please show me where I have even *implied* that the "air that is compacted behind the prop [is] the only operative force on the prop".
Again, I don't think you can produce the evidence to support your assertion that I focus on the area behind the prop and ignore the area in front of. You certainly haven't produced a quote to imply that yet at least, and I'll be happily waiting.
JB
  • #824
OK. This is all I wanted. Any implication I saw was simply the result of your not mentioning it assuming it was understood. I made a spurious connection between your stand and what I take Jeff's to be. Conceptually, then, I can see your cart working, while Jeff's, I cannot.
  • #825
ThinAirDesign said:
Of course it is -- no one questions that, but we don't argue about whether it's the same wind turbine as the one up on the hill do we? We don't argue about whether it works exactly the same way do we?
What *creates* the wind is irrelevant to a wind powered device -- it's doesn't know nor does it care. Solar wind (outdoors), nuke wind (aircraft carrier), elecric wind (wind tunnel, treadmill), gravity (river), all the same to a turbine, sailboat, DDWFTTW cart.
One more time, a wind turbine, sail and DDWFTTW cart are all examples of wind powered devices -- arguments about what powers the wind that powers the devices are not relevant to the details of how a wind powered device works.
JB
In your example the wind loosely couples the windmill to the steam turbine. You could have done the same thing with a belt and been more efficient.
You have to look at the entire system.
  • #826
Jeff Reid said:
Well just imagine than an outdoor wind is being generated by steam powered wind turbines. Does it matter what the power source is that creates the relative wind?
Not to the windmill but it does to anyone trying to get energy out of the system (windmill + steam turbines)
Maybe we can use the electricity from the windmill to heat the water that powers the turbines.
Would that work?
  • #827
How can the lower pressure in front of the blade pull the blade? It is still pressure - it doesn't pull, it pushes. But it pushes less than the higher pressure behind the blade.
The cart gets momentum from the difference between the push from behind and the push from the front (pressure difference). There is no pull, only pushing. How should air molecules actually pull something?
  • #828
To see what?
  • #829
Would that work?
No, you can't. Now that would take an over unit device. His point about the cart working is that it does not care where it gets its energy from. There is a lot of energy in the wind that could be harvested to power the cart. There is also a lot of energy from the treadmill producing a relative wind that can power the cart. A lot less energy is harvested by the cart than there is in the actual system.
JB, I know a way that a sail cart could beat the prop cart, we just don't limit the cart to directly downwind. Of course if it is a directly downwind race the cart would win hands down.
  • #830
It's a casual manner of speaking to make a point clear. The low pressure "pulls" in the same way a vacuum cleaner "sucks".
  • #831
Me:
A wind turbine generates just as much electricity bolted to the deck of an aircraft carrier steaming at 15 knots on a still air day as does one mounted on the ridge in a 15 knot wind. Wind turbine can't know. Wind turbine doesn't care.
Tsig responds:
It matters not how "loosely coupled" the other relationships are -- that's the entire point of the example; there's a solid relationship between the deck and the turbine. The deck moves and the turbine spins.
It doesn't matter that the sun shone and the photosynthesis caused plants to grow which were eaten by herbivores which were then eaten by the carnivores which died and became crude which was refined and burned to make the steam to drive the turbine which moved the freakin' deck. The only relevant point is ... power the deck however you wish and in the end as long as the deck moves, the turbine can't tell the difference.
No you don't. To analyze the wind turbine you need not look any farther than what the turbine can see -- the wind. It matters not what creates it.
To analyze the DDWFTTW cart, you need not look any farther than what the turbine can see -- the wind. It matters not what creates it.
JB
  • #832
OK here is my explanation of your points with regard to the video:
(1). In your video, this does not quite happen. The closest the cart comes to this is right at the very beginning, T = 7 seconds, when the TT starts up and the cart momentarily moves at nearly the same speed, both moving CW. The wheel is obviously turning because the propeller is turning. They are linked by a flexishaft, remember?
(2). Yes. At T = 8 seconds both the cart and the TT are still accelerating and moving in the same direction, CW and the TT linear velocity is greater than the cart’s linear velocity on the wheel circumference.
(3) This is true for as long as they are going in the same direction only! At T = 12 seconds, the cart is moving at it’s Max speed because it is still moving CW with the TT. If you had a tach on the wheel, HERE is where you would record the highest RPM.
(4). Yes the Difference increases because the cart starts to slow down! The TT does not accelerate continuously does it? At T = 13 seconds, the cart is seen to be stationary for a moment on the TT. At this point, the linear velocity on the edge of the wheel is exactly the same as the linear velocity on the surface of the TT. This is a critical point.
(5) NO. Again, the Difference increases because the cart is slowing down and the TT is no longer speeding up. At T = 17 seconds the cart has reached its terminal linear velocity, which is less than at T = 12 seconds. From this point onwards, the TT and the cart are in a heterodyne. The translation of the cart in the CCW direction (measured in m/sec) is the Difference between the linear velocity of the TT surface in m/sec MINUS the linear velocity at the wheel in m/sec.
If you can give me very accurate dimensions of the TT diameter, wheel diameter, and a very accurate measurement from center of TT to center of the track of the wheel, and the RPM of the TT, I can calculate the ballpark figures for the RPM of the wheel at T = 12 seconds (High RPM) and T = 13 seconds (RPM where wheel linear velocity equals TT linear velocity) and at T = 17 seconds (when the wheel linear velocity is LESS then the TT linear velocity and it is translating) But it is much preferable that you put a tach on the wheel and measure this directly.
I can give you a calibration method if and when you are ready to do this test. Thanks!
  • #833
schroder, when are you going to see that the important velocity is the velocity of the cart relative to the turntable. If the velocity of the turntable at the rim is 10 m/s that is modeling a wind speed of 10 m/s. If the cart is stationary w.r.t. the ground that means its wheels are rotating at a speed that would translate as 10m/s. Once the cart starts moving counterclockwise w.r.t. the ground it indicates that the wheel speed of the cart is faster than the "wind" that is modeled by the turntable.
  • #834
----- Jeff Reid:
Yes, and lucky for us we're not trying to get energy out of the system. The cart's a user, not a producer. We don't care how much "wind" we use to go DDWFTTW, nor do we care how much sun/electricity/petrol it took to power that wind.
We don't claim that it's cheap to go DDWFTTW --- just that it's easy. :smile:
Maybe we can use the electricity from the windmill to heat the water that powers the turbines. Would that work?
No better than us claiming that we could put a generator on the cart to power the treadmill. That's a flat impossible claim.
Just as it takes an *outside* source of power to turn a wind turbine, it takes an *outside* source of power to go DDWFTTW. It's just that neither we nor the turbine nor the cart give a flyin' flip what that source is.
JB
  • #835
I thought I covered this in an earlier post.
The prop accelerates the air upwind, and it doesn't matter how much of this acceleration takes place fore (via reduction in pressure) or aft of the prop (via increase in pressure), just the total acceleration. (more on this below).
The upwind acceleration of the air, ends up slowing down the speed of the air in the vicinity of the prop with respect to the ground, and it's reduction of wind speed versus ground speed that powers any wind powered (wind speed versus ground speed) device.
I've done a little googling and find that the faster, lower pressure air on the front surface of the props blades does not slow down upon meeting the slower air behind the blades.
For a typical situation, the air speed across the prop disk changes little, while the pressure increases significantly, and this is called pressure jump. The thrust from a prop equals this pressure jump times the cross sectional area swept by the prop disk. The pressure jump increases the air pressure above ambient, and the air then continues to accelerate aft of the prop as it's pressure returns to ambient. There is a term called "exit velocity" which is the speed of the air when it's pressure returns to ambient. Link to NASA prop analysis which covers this fairly well including your concern about Bernoulli (it applies before and after but not during the time when air crosses through the propeller "disk", because the propeller peforms work on the air):
http://www.grc.nasa.gov/WWW/K-12/airplane/propanl.html
  • #836
tsig said:
When you look at the whole system you see that the windmill on the carrier is being powered by the carrier's steam turbines.
tsig said:
Not to the windmill but it does to anyone trying to get energy out of the system (windmill + steam turbines). Maybe we can use the electricity from the windmill to heat the water that powers the turbines.
I stated steam powered wind turbines, ones that input mechanical (thermal) energy and output wind, not windmills. My point was to compare a steam powered propeller or turbine used to generate a wind to drive the cart to the steam powered spools that retracted the wires to drive a Brennan torpedo.
  • #837
Yep, and this is why I'm likely not doing any test until he specifies and we agree on what he's asking for. So far he's being a wuss and won't specify.
Clearly (to those who utilize the normal laws of physics) if we place a sail cart and a prop cart next to each other and aim them both DDW, the prop cart will destroy the sail cart.
Schroder(who subscribes to a rather abnormal set of physics laws) has stated he believes otherwise but apparently has come into some doubts recently.
JB
  • #838
Yes, in casual manner you can say that the lower pressure is pulling, instead that the higher pressure is pushing more. But this are only two ways to describe the very same thing: net force from relative pressure difference.
You seem to argue (and I rejected that) that these are two different effects that add up, and both need to be taken into account / considered as separate contributions:
  • #839
A.T. said:
Yes, in casual manner you can say that the lower pressure is pulling, instead that the higher pressure is pushing more. But this are only two ways to describe the very same thing: net force from relative pressure difference. You seem to argue (and I rejected that) that these are two different effects that add up, and both need to be taken into account / considered as separate contributions.
Well they could be considered separate aspects of a propeller. How the propeller reduces the air pressure fore of the propeller doesn't have to be related to how the propeller increases pressure at the propeller, and the two effects combined contribute to acceleration of air. One major difference is that Bernoulli applies fore of the propeller, but not at the propeller where the total energy of the air is increased (relative to the prop), mostly the pressure. Aft of the propeller disk, Bernoulli applies again as the air continues to accelerate and decrease in pressure back to ambient.
  • #840
My point was that it is the pressure difference that matters, and not how it is achieved: reducing pressure fore of the propeller, increasing pressure aft of the propeller or both. I do not understand why zoobyshoe thinks that DDWFTTW could only work if pressure fore of the propeller is reduced:
This "forward pull by lower pressure" is just a casual description of the "bigger push by the higher pressure against smaller push by lower pressure". These two don't add up. They are the same thing.
  • · Replies 47 ·
12K
  • · Replies 26 ·
  • · Replies 48 ·
12K
10K
