De Broglie relation using four momentum in particle physics
crick
In particle phyisics four-momentum is used and De Broglie relation is used to understand what lenghts can be "seen" in an experiment.
Here (page 6) https://people.phys.ethz.ch/~pheno/PPP/PPP2.pdf it is claimed
The key factor for investigating the proton substructure is the wavelength of the probing
photon, which is related to the transferred momentum by
$$\lambda\sim \frac{1}{\sqrt{Q^2}}$$
Where ##Q^2## is not actually "momentum" but its the square of the four momentum transferred by the photon.
I can't understand why this is used, since the square root of square of four momentum is
$$\sqrt{p\cdot p}=\sqrt{|\textbf{p}|^2-E^2/c^2}$$
While De Broglie relation usually involves the three momentum ##\textbf{p}##
$$\lambda\sim \frac{1}{|\textbf{p}|}$$
So is in this case ##\sqrt{Q^2}## approximately the three momentum? Or is the De Broglie relation in the relativistic case to be written using ##\sqrt{Q^2}## instead of three momentum?
Not sure if this will help but wikipedia has an article on matter-waves:
https://en.wikipedia.org/wiki/Matter_wave
and toward the end they describe how they use four-vectors to reduce the deBroglie relations to a single equation:
Four-vectors[edit]
Main article: Four-vector
Using four-vectors, the De Broglie relations form a single equation:
4688eb69effac4468cd9f3a2c2f253ea8969a0f5
which is frame-independent.
Likewise, the relation between group/particle velocity and phase velocity is given in frame-independent form by:
1fbd329f20b16a9bf02c0fa4a96ba311501f0ce9
where
Four-momentum
03339f93e4c7a61b8a92df9658bc8f148059b800
Four-wavevector
d4213cdba2252aaf70a66e2ae10582b86697b655
Four-velocity
874798397ccd9bcb79f01803848df1626b7551b1
