De Broglie wavelength neutrons
In summary: Yourself, or someone else?In summary, the de Broglie wavelength of the neutrons in units nm is 4.973E-11 m.
weeksy
Question-A certain crystal has a set of planes spaced 0.376 nm apart. A beam of neutrons strikes the crystal at normal incidence and the first maximum of the diffraction pattern occurs at a scattering angle (i.e angle between incoming neutrons and reflected beam) of 41.4 degrees. What is the de Broglie wavelength of the neutrons in units nm and to 3 decimal places.
Usefull equations -
2d sin theata = nλ
where d = plane spaceing, n is the order in this case =1
My Attempt-
useing above eqn,
2*0.0376E-9 (m)*sin(41.4)=4.973E-11 m
I have been told that this solution is wrong as the question states "at normal incidence" which apparently complicates things and makes a need to change the angle theata. Any suggestions? thanks in advance.
Right, real simple. Try drawing a picture and then revisit what they mean by "angle between incoming neutrons and reflected beam" and make sure you drew it correctly.
You're almost there.
yeah its the drawing which is what is stuffing me up. when i draw a picture i have the neutrons comeing in at 90 degrees to the plane ie normal and the reflecting out at 41.4 degrees. but i don't think this is right?
Perform an internet search for "Bragg Diffraction."
Well done. Now think on that for a bit.
Looking at the question again it states that the neutrons are hitting the plane normal ie at theata = 90 degrees which is the dotted line on that diagram right. Also we know the first maximum of the diffraction pattern occurs at a scattering angle (i.e angle between incoming neutrons and reflected beam) of 41.4 degrees.
So does this mean that as theata is measured with respect to the plane, theata is 90-41.4?
Excellent! That's the second step. We're missing the first one. Nearly there. Think about where the "angle between incoming neutrons and reflected beam" is.
well the angle (phi) is the angle between incomming neutrons and reflected beem, and in our case phi= 41.4 degrees. So what am i missing? thank you very much for your patience.
No troubles. You've done quite well. Great picture. I believe you're a good student for being so patient yourself.
Answer: We need to halve it.
Then do what you were saying.
I see, so we have 90-1/2phi
=90-20.7
=69.3 degress
and from this we can plug theata into the 2dsintheata=nlambda
correct?
Time to celebrate.
thank you very much.
1. What is the De Broglie wavelength of a neutron?
The De Broglie wavelength of a neutron is the wavelength associated with its wave-like behavior. It is given by the equation λ = h/mv, where h is Planck's constant, m is the mass of the neutron, and v is its velocity.
2. How is the De Broglie wavelength of a neutron different from that of other particles?
The De Broglie wavelength of a neutron is unique because neutrons have a mass that is similar to that of protons, but they do not have an electric charge. This means that they are not affected by electric fields, unlike other particles such as electrons.
3. What is the significance of the De Broglie wavelength of neutrons?
The De Broglie wavelength of neutrons is important because it demonstrates the wave-particle duality of matter. It also helps to explain certain phenomena, such as neutron diffraction and interference.
4. How is the De Broglie wavelength of neutrons measured?
The De Broglie wavelength of neutrons can be measured using various techniques, such as neutron scattering experiments or neutron interferometry. These experiments involve passing a beam of neutrons through a material or a series of slits and measuring the resulting diffraction or interference patterns.
5. Can the De Broglie wavelength of neutrons be changed?
Yes, the De Broglie wavelength of neutrons can be changed by altering their velocity or mass. This can be achieved by accelerating or decelerating the neutrons, or by changing their energy levels through interactions with other particles.
  • Quantum Physics
  • Quantum Interpretations and Foundations
