Debunking the Myth: The Truth About Sunlight and Color Scattering
  • Context: High School
  • Thread starter Thread starter Holocene
The discussion revolves around the scattering of sunlight and its relationship to color perception, focusing on the mechanisms behind why the sky appears blue and the nature of sunlight's spectrum. Participants explore concepts related to light scattering, color perception, and the physical properties of atmospheric particles.
  • Some participants assert that blue light is scattered more than other colors, while others question this claim, suggesting that blue light might be scattered less.
  • There is a discussion about color perception, with some participants proposing that colors are perceived as the absence of certain wavelengths, specifically in the context of green leaves.
  • One participant argues that blue and violet light scatter more due to their higher frequency, affecting how we perceive the sky at different times of day.
  • Another participant notes that sunlight does not produce a perfect spectrum when refracted, indicating that some spectral lines are missing, which is attributed to the nature of the gases in the sun.
  • Questions arise regarding the sources of scattering, specifically whether it is due to static air molecules, dynamic air molecules, or dust particles, with references to Rayleigh and Mie scattering provided.
Participants express differing views on the scattering of blue light and the nature of color perception, indicating that multiple competing views remain without a clear consensus.
Some claims about color perception and the scattering mechanisms depend on specific definitions and assumptions that are not fully resolved in the discussion.
Holocene
"Sunlight contains all colors. When light rays strike molecules in the atmosphere, some of the light bounces off in a new direction (scattering). The blue light is scattered more than other colors, so to our eye it seems to be coming from all directions, not just from the sun."
Isn't it the blue light that is scattered LESS than the other spectrums?
Science news on Phys.org
We percieve colours as its absence. A green leaf is due to it emmitting 'all' wavelengths but green.
The first is true, the second is not. For the sky, consider that if the blue light wasn't scattered, we wouldn't see it coming at us from all directions. For the perceiving colors by their absence, I'm not sure where you get that, but it isn't correct.
Denton said:
We percieve colours as its absence. A green leaf is due to it absorbing 'all' wavelengths but green.
Fixed it for you.
Blue and violet do indeed scatter more. They are high frequency, and behave like hyper children; bouncing all over the place. At short range, like when the sunlight is coming strait down through the atmosphere, this makes the sky look blue because the blue light is all over the place. At greater depths like sunset (when sunlight is cutting through a lot more atmosphere), the scattering of blue light means that most of it is dispersed before reaching the ground, and the deeper-penetrating low frequencies (at the red end of the spectrum) dominate because they didn't get scattered as much.
This is not entirely true. If we refract sunlight we will notice that you don't get a perfect spectrum, some of the lines will be missing, this is true for all stars. However I think the sun has a fairly complete spectrum.
This is due to the nature of the gas that comprises the star
What frequencies are missing?
http://chinook.kpc.alaska.edu/~ifafv/lecture/fraunhofer.htm
I think the full image is at the bottom.
Does the blue sky arise mostly from scattering off of relatively static air molecules, dynamic air molecules, or dust particles?
GleefulNihilism said:
Quote:
Fixed it for you.
"We percieve colours as its absence." This sentence is still there? How did you fix it then :smile:? We perceive green because it's the only one present...
Raleigh scattering takes place when 2pi*r/lambda <<1, where r is the characteristic dimension of the particle. For sunlight in air, the scattering particles are the Oxygen and Nitrogen molecules. The intensity of the scattered light is inversely proportional to lambda^4. So, the lower wave lengths, like the violet and the blue, scatter more.
There is an erroneous idea that dust particles or tiny droplets of water vapour can also cause Raleigh scattering, but their sizes are just too big. For them, the right treatment would be Mie scattering. The white colour of the sky near the sun can be treated according to the latter.
  • · Replies 22 ·
  • · Replies 40 ·
12K
