Cameron Rose
- 1
Hi guys, I'm new to this site so forgive me if I'm unfamiliar with any etiquette unique to here. We did a practical exercise the other day in class in which we accelerated a bogey to a certain RPM and then released it to accelerate up a ramp. We were then given a sheet of the measurements I have listed below and told to go home and write a report calculating predicted values for the distance traveled up the ramp and compare the values to the distance we had measured. Friction is negligible.
Given measurements
Mid ordinate power values
Time = 6.3s (from release to maximum potential energy)
Mass = 0.626 kg
Initial RPM = 750 RPM
Distance traveled up slope = 2.27 m
Height at max distance = 0.04 m
Measurements calculated/known so far
Average Power = 1.38 W
Total Ek = 10.488 J
Angular velocity = 25pi rad/s
Angular Ek = 0.8326 J
Linear Ek = 9.6554 J
Initial velocity = 5.55 m/s
Final velocity = 0 m/s
E = Pt
E = 0.5Iw^2 (substituting omega for w)
E = 0.5mv^2
v^2 = u^2 + 2as
F = ma
F = mg
Calculated average power, then used E = Pt to determine total kinetic energy.
Stated that Ek (total) = Angular Ek + Linear Ek
Used values of mass and radius to calculate inertia for each component. (Values not listed as I'm confodent this is correct.
Calculated Angular Ek using E = 0.5Iw^2 for each component then summed them for total.
Calculated Linear Ek using Ek (total) - Angular Ek
Calculated Initial Velocity using E = 0.5mv^2
I think I now need to draw a diagram and resolve parallel and perpendicular values for the force?
Then use F = ma to calculate deceleration?
Then use v^2 = u^2 + 2as to calculate displacement?
If someone could confirm/correct my thought process there it would be brilliant.
Cheers,
Cameron.
Given measurements
Mass = 0.626 kg
Total Ek = 10.488 J
[/B]E = Pt
E = 0.5mv^2
v^2 = u^2 + 2as
F = ma
F = mg
Cheers,
Cameron.
