Can Any Linear Operator Be Decomposed into Hermitian Components?
dingo_d
Show that any linear operator \hat{O} can be decomposed as \hat{O}=\hat{O}'+i\hat{O}'', where \hat{O}' and \hat{O}'' are Hermitian operators.
Operator is Hermitian if:
T=T^{\dagger}
I don't know where to start :\ Should I try to see for some arbitrary vector |\psi\rangle, that I can write it in some basis, and see what it would do to write eigenvalue equation with those operators?
Play with \hat{O}^\dagger+\hat{O} and i(\hat{O}^\dagger-\hat{O}).
Hmmm.
So \hat{O}^{\dagger}+\hat{O}=\hat{O}'^{\dagger}-i\hat{O}''^{\dagger}+\hat{O}'+i\hat{O}'' and since those with ' and '' are hermitian it follows:
\hat{O}^{\dagger}+\hat{O}=\hat{O}'-i\hat{O}''+\hat{O}'+i\hat{O}''=2\hat{O}'
Am I on the right track?
Not too bad ...
XD Too bad? XD
For the i(\hat{O}^\dagger-\hat{O}) part I got 2\hat{O}''
So I should somehow prove linear superposition or?
Well, so what is your guess for O' and O''? Guess what they should be, then check carefully if your guess has all the required properties.
This is how we often solve problems: we play, we guess, and the we check carefully, in all detail, if our guess really constitutes a solution of the original problem. The way towards a solution does not have to be logical. What needs to be logical is the verification.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
