Definite and indefinite integration in the definition of work
The discussion revolves around the definitions and applications of definite and indefinite integrals in the context of work, momentum, and kinetic energy in classical mechanics. Participants explore how these integrals relate to changes in physical quantities and the implications of using one over the other.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants propose that definite integrals are used to model changes in quantities, while indefinite integrals are used to find defining functions of those quantities.
  • One participant illustrates this with the force-momentum relationship, noting that definite integrals yield changes in momentum or impulse, whereas indefinite integrals provide a function for momentum.
  • There is a suggestion that work is commonly defined as an indefinite integral, which leads to confusion since it appears to define kinetic energy instead of change in kinetic energy.
  • Another participant emphasizes that work is typically represented as a definite integral, which aligns with the definition of net work as the change in kinetic energy.
  • Some participants discuss the concept of variable bounds in definite integrals and how they relate to changing kinetic energy or momentum over time or distance.
  • One participant raises the issue of the constant of integration (C) in indefinite integrals, suggesting that it complicates the understanding of the relationship between indefinite and definite integrals.
  • A later reply introduces the idea of representing momentum in relation to different inertial reference frames, suggesting that while momentum can be expressed using indefinite integrals, it becomes definite once a reference frame is chosen.
  • There is a mention of the implications of this discussion in the context of General Relativity, where the concept of reference frames differs from classical mechanics.
Participants express differing views on the definitions and applications of definite versus indefinite integrals, particularly regarding their roles in defining work and momentum. The discussion remains unresolved, with multiple competing perspectives presented.
Participants note that the indefinite integral is not a function but rather an equivalence class of functions, which may lead to confusion in its application. The discussion also highlights the dependence on the choice of reference frames in classical mechanics.
etotheipi
This is going to sound like a silly question, but here we go anyway! I've always thought about a definite integral being used for modelling a change in some quantity whilst an indefinite integral is employed to find the defining function of that quantity.
For example, consider the force-momentum relationship $$F dt = dP$$ If we integrate definitely from t1 to t2, we will get a change in momentum or impulse:$$\int_{t_{1}}^{t_{2}} F dt = \int_{t_{1}}^{t_{2}} dP = P_{2} - P_{1} = \Delta P = I$$whilst a definite integral will instead allow us to pick a constant of integration to find the function which outputs the momentum at any given time:$$\int F dt = P + C$$It is a commonly used definition that work is the integral of force with respect to displacement, but it is usually written as an indefinite integral. This is confusing to me, since the indefinite integral of a force with respect to displacement appears to define the kinetic energy of the body:$$\int F dx = \int mv dv = E_{k} + C$$
On the other hand, a definite integral from position x1 to x2 defines a change in kinetic energy, and the net work is also commonly defined as the change in kinetic energy of a body, like the following
$$W = \int_{x_{1}}^{x_{2}} F dx = E_{k2} - E_{k1} = \Delta E_{k}$$
Is the quantity work more precisely defined as a definite integral as opposed to the indefinite definition which seems to be everywhere?
In general, these things are always definite integrals.
You can, however, have a definite integral with variable bounds - usually the end point. This creates the variable KE or momentum as a force acts over a variable time interval or distance. So, for example:
##p(t) = p(0) + \int_0^t F(t')dt'##
Writing:
##p(t) = \int F(t)dt##
Is a bit sloppy, I would say.
Writing:
Thank you, that clears up a lot of confusion!
It's the value of C that seems to be the difficulty. How are you going to find it without working out, effectively, a definite integral somewhere? The indefinite integral is only half the story.
Actually, a further thought. In classical mechanics we are normally using an inertial reference frame, as defined by Newton's first law. If we pick a reference frame then the momentum has a definite value, as a function of time. That's represented by the definite integral above.
But, you might ask whether the momentum can be represented more generally, independent of any particular inertial reference frame. For that you could use the indefinite integral. Note that mathematically an indefinite integral is not a function, but an equivalence class of functions. The momentum, therefore, is also an equivalence class of functions, one for each inertial reference frame.
The quantity common to all inertial reference frames is the change in momentum. The actual momentum itself depends on choice of frame.
In this case, however, you would need to make clear that's what is meant. Once you choose a reference frame, then the integral becomes definite; and the momentum is resolved to a specific function.
In fact, not to get too far ahead, being able to think of a quantity like momentum in this way eventually becomes essential in General Relativity, where there are no global inertial reference frames. But that's a story for another day.
  • · Replies 18 ·
  • · Replies 48 ·
  • · Replies 48 ·
  • · Replies 43 ·
  • · Replies 31 ·
