Definite integration by U subsitution
  • Thread starter Thread starter steel1
    Integration
The forum discussion focuses on solving the integral 4∫√(t)(10+t)(dt) using U substitution. Participants clarify that the correct substitution is u = √t, leading to du = (1/2√t)dt. The discussion emphasizes that incorrect substitutions, such as u = t, do not facilitate the integration process. Ultimately, the community encourages users to follow the guidance provided by experienced members to successfully complete the integration.
  • Understanding of integral calculus
  • Familiarity with U substitution technique
  • Knowledge of differentiation rules
  • Ability to manipulate algebraic expressions
  • Practice U substitution with different integrals
  • Learn about integration by parts
  • Explore advanced integration techniques such as trigonometric substitution
  • Review the properties of definite integrals
Students studying calculus, particularly those seeking assistance with integration techniques, and educators looking for examples of collaborative problem-solving in mathematics.
steel1
∫√(t)(10+t)(dt)
note, only the t is under the square root.
Ok. I have to solve this integration problem by U substitution.
To start, I am not entirely sure what to even set U equal to. I let it equal the number under the square root.
So,
U=t
Du=dx
But where do i go after this?
Hey there, welcome to PF.
Your substitution is wrong, and your derivative as well. You should've gotten u = t so du = dt.
That will still be wrong though.
Try the substitution u = \sqrt{t}.
ok. If i set U=√t and Du=dt, where do i go from there? the du=dx was a typo.
No, if u=√t du will not equal dt. For the purposes of figuring out the substitution for dt it will be more helpful to write the substitution as u2=t. What does that give when you differentiate?
derivative of u^2=t is 2u=1?
If somebody could just do the entire thing via U substitution, that would be great. Then I can see how you did it. I'll be refreshing this page every few minutes.
steel1 said:
∫√(t)(10+t)(dt)
That's clear from the parentheses you have.
So,
U=t
Du=dx
This is NEVER a good substitution, since all you're doing is changing to a different letter. Also, the second line should be du = dt, not du = dx.
Do you have to use a substitution?
If not, rewrite the integrand this way:
√(t) (10 + t) = 10√(t) + t√(t) = 10t1/2 + t3/2
Yeah, this is what i have so far
U^2=t
2du=dt
yes, i would prefer to solve this by u substitution, so i can see how its done.
No on two counts. First, you're not taking derivatives - you're getting the differentials of u2 and t.
Second, the differential of t is dt, not 1.
Here's how it works for both sides:
d(u2) = d(u2)/dt * dt = 2u * du
d(t) = d(t)/dt * dt = 1 * dt
You're new here, so there's a good chance you haven't looked at the forum rules, even though you said you did when you signed on. Take a look at the rules by following the link, especially the Homework Help section.
You'll see that we won't do the work for you, but we'll help you do the work by guiding you in the right direction.
OK, that's a reasonable reason. Follow the suggestions made by Zondrina and haruspex.
  • · Replies 105 ·
  • · Replies 22 ·
